Anyone know of a solution that I can place in between an outlet plug? US, 15 amp?
Like a kill a watt?
Are there current transformers that I can use here. I am trying to monitor the power before a UPS for a strange issue.
Like a kill a watt?
You may find US versions of a ‘Tuya’ plug (it is a generic Chinese manufacturer) or one of the Sonoff plugs now does energy monitoring I believe.
A Kill-a-Watt can handle a max of 1800 Watts.
Does your UPS draw exceed that number?
Do you want/need to record the data?
you can try this if you like
i use a zigbee versions myself and track fine at individual outlets … but this wifi version which personally have not tried
Really I am just trying to figure out what is going on with some power at some locations that do not have ups’s with snmp cards…
I think I may just have to upgrade the ups units.
I am looking primarily for power loss, and voltage brownouts.
the ups probably has a serial connection you can connect and grab that data . if your ups supports it , NUT and a pi or arduino/esp based version if you’re more energetic … but I probably get a orange pi zero for $15 install armbian and use NUT… if your UPS supports NUT…
or other option buy this and connect to a rs485 capable esp or pi to gather decrypt and send data to you
or as mentioned Sonoff
many option only limited by your imagination and price point
