Hello, good afternoon
I have a problem when I enter through the wormhole of dataplicity it hangs and does not allow to load the config.js file gives error 403, doing it in a localhost way everything works fine.
Hello @b31k annoyingly I’ve started to see the same issue here, it looks like dataplicity must be blocking access to scripts with that name across the board… I’ve sent them a message to investigate
