Local access to emoncms
I have a level 3 monitoring setup gathering data from my Vaillant heat pump. data is present on the cloud but I would like to access it locally. When attepmting to access locally I am asked for username and password. Having read the online tips and hints, emonsd does not work. Username does not exist. There is also no option to register. Any ideas what to do next please?
TIA
I understand you should have received a printed sheet with your Heat Pump Monitor. The details you need are near the bottom.
I’ve sent you a link in a PM.
The default local login is emonhp / emonhp
Thank you
