I just had automatic update after a restart caused by power loss. It updated from low-write Version 10.2.7 to the latest build 10.5.6. Now one of my Serial Inputs stopped working.
I am using 2 Inputs total, both UART Serial. The one coming from an ESP32 for Energy is still working, the one from Arduino Pulse counter stopped.
I inserted my backup SD card with Version 10.2.7, and both serial Input works, so there is no problem with the Arduino sending Serial data.
There is a slight possibility that the upgraded 10.5.6 got corrupted during power loss. But unlikely, that it just caused a serial feed to stop working. Everything else is fine. I did have to run “cd /var/www/emoncms && git pull”, to get all the sidebar and top menus to appear again after update.
[[SerialTx3e]]
Type = EmonHubTx3eInterfacer
[[[init_settings]]]
com_port = /dev/ttyAMA1
com_baud = 115200
[[[runtimesettings]]]
pubchannels = ToEmonCMS,
nodeoffset = 9
[[9]]
nodename = emontx5
[[[rx]]]
names = pulse1, pulse2, pulse3, pulse4, pulse5, pulse6, pulse7, pulse8, pulse9, pulse10, pulse11, pulse12
datacode = 0
#datacodes = L,L,L,L,L,L,L,L,L,L,L,L
scales = 1,1,1,1,1,1,1,1,1,1,1,1
units =p,p,p,p,p,p,p,p,p,p,p,p
