Key to Visualisation Options
I would like to do something simple and create a bar graph visualisation for kwh per calendar month. I can make one for days by setting the interval in seconds. The docs say use the ‘mode’ but this is missing. Also, what does ‘dp’ mean.
Hello @mblinko have you tried using the Graph module?, here’s an example converting a cumulative kWh feed into monthly values. Note type: Monthly and Delta ticked.
