I’ve just installed an new instance of EmonSD and migrated my data. At first glance it seems OK, but on the sidebar of the web interface, I’m getting illegal string & illegal offset errors -
Warning : Illegal string offset ‘path’ in /var/www/emoncms/Theme/basic/sidebar_view.php on line 239
Warning : Illegal string offset ‘href’ in /var/www/emoncms/Theme/basic/sidebar_view.php on line 240
Warning : Illegal string offset ‘path’ in /var/www/emoncms/Theme/basic/sidebar_view.php on line 242
Warning : Illegal string offset ‘href’ in /var/www/emoncms/Theme/basic/sidebar_view.php on line 244
Just tried clearing browser cache across Chrome/Firefox/Brave still the same.
It’s a fresh install of the Oct2018 image on a Pi2.
Lines removed from the config.txt to allow Pi2 to boot. SSH activated.
Partition expanded to fill 16GB SD card.
1.7GB of data imported from current Pi2.
Hello Vster, you may need to run database update from the admin menu, the import process copies over the old mysql database and its likely that there have been changes associated with v10 that need a database update, you should only need to click on ‘update database only’ on the admin page:
