Is it normal that the wires from the controller needs to be crossed while the rest linking the modules are straight ?
I see a lot of conflicting setups some seem to have all straight leads some seem to have all crossed leads , and mine seems to only work with a mixture ?
edit
worked it out , because I was not using 90 deg connectors when I copied the position to put the headers from the one near the ISP I did not rotate the header so all of the headers are backwards on the modules
