Hi folks,
I understand VNC is now part of the Raspbian build, and if I run raspi-config, and select Advanced Options, I see the option to enable/disable VNC, and if I select Enable, I get the message "The VNC Server is " with nothing else. According to the Raspberry site, I should be able to issue the command “vncserver” to start the vnc server if I am running in headless mode (which I am), but that just fails with “command not found”. I’ve done a search, and can’t find anything called vnc, so I assume it has been removed to reduce the image size?
If so, any suggestions on installing it, before I follow the Real VNC guide to installation?
Cheers
