Was just wondering if there’s any other forums to get help with different aspects of the diybms system.
Ive gotten some great help here but seems to take quite a while. I have a few threads I’ve started that still haven’t had any replys and I’m sort of at a stand still.
I have all my boards populated and programmed, and all of my cell modules for my 8KWh battery Welded and ready to go but I can’t wrap them with insulation paper and heat shrink them and put the entire thing together until I can figure out a few things.
One of them being the ntc 10k thermistors reading improper temperatures on the diybms dashboard. Hopefully I can calibrate them in the dashboard or modify the code for the cell modules to read accurately… I’ve tried changing the coefficient settings but didn’t help.
I have a ton 10K NTC thermistors I’d rather use before I have to buy the ones recommended by @stuart.
Here are the specs:
MF58103F3380
Resistance in Ohms @ 25°C - 10k
Resistance Tolerance: ±1%
B25/50 - 3380K
Operating Temperature -55°C ~ 200°C
With all that said I 100% appreciate all the work the @stuart and the community have done to make this project possible. I think it’s incredible. I just need help with a few things so I can button-up my project and move on to my next large battery build. Which I also plan on using diybms. I’ve purchased hundreds of pcbs and plan on using the diybms for the foreseeable future
