Hi Team,
Have noticed that my IoTaWatt is often rebooting, and today noticed that it has stopped uploading to EMON CMS. Not sure if the issue is at the IoTaWatt end or EMON CMS end.
I have noticed that the unit is still on 02_02_24 even though I have set updates to Beta.
Below are screen shots and logs.
Thanks!
Log:
11/30/17 17:24:44 ESP8266 ChipID:3134734
12/1/17 03:24:44 device name: IotaWatt, version: 3
12/1/17 03:24:44 Local time zone: 10
12/1/17 03:24:47 Connecting with WiFiManager.
12/1/17 03:24:48 MDNS responder started
12/1/17 03:24:48 You can now connect to http://IotaWatt.local
12/1/17 03:24:48 HTTP server started
12/1/17 03:24:48 dataLog: service started.
12/1/17 03:24:48 dataLog: Last log entry:1512062680
12/1/17 03:24:48 statService: started.
12/1/17 03:24:48 timeSync: service started.
12/1/17 03:24:48 WiFi connected. SSID: Dan, IP: 10.1.1.26
12/1/17 03:24:53 EmonService: started.url: emoncms.org:80, node: IotaWatt, post interval: 10, encrypted POST
12/1/17 03:24:53 EmonService: Start posting from 1511414770
12/1/17 03:25:00 EmonService: POST failed. HTTP code:read Timeout
12/1/17 03:26:00 EmonService: Resending EmonCMS data:2
12/1/17 03:28:01 EmonService: Resending EmonCMS data:3
12/1/17 03:31:02 EmonService: Resending EmonCMS data:4
12/1/17 03:35:03 EmonService: Resending EmonCMS data:5
12/1/17 03:40:04 EmonService: Resending EmonCMS data:6
12/1/17 03:46:05 EmonService: Resending EmonCMS data:7
12/1/17 03:53:06 EmonService: Resending EmonCMS data:8
12/1/17 04:01:07 EmonService: Resending EmonCMS data:9
12/1/17 04:10:08 EmonService: Resending EmonCMS data:10
12/1/17 04:10:09 EmonService: Unable to post to Emoncms after 10 retries. Restarting ESP.
** Restart **
No clock yet: SD initialized.
11/30/17 18:10:11 Real Time Clock is running. Unix time: 1512065411
11/30/17 18:10:11 Version: 02_02_24
11/30/17 18:10:11 Reset reason: Software/System restart
11/30/17 18:10:11 Trace: 17,18,13,14,15,16,17,18,13,14,15,16,17,18,13,14,15,30,37,38,148,149,140,142,143,144,145,148,149,146,147,39
11/30/17 18:10:11 ESP8266 ChipID:3134734
12/1/17 04:10:11 device name: IotaWatt, version: 3
12/1/17 04:10:11 Local time zone: 10
12/1/17 04:10:14 Connecting with WiFiManager.
12/1/17 04:10:19 MDNS responder started
12/1/17 04:10:19 You can now connect to http://IotaWatt.local
12/1/17 04:10:19 HTTP server started
12/1/17 04:10:19 dataLog: service started.
12/1/17 04:10:19 dataLog: Last log entry:1512065405
12/1/17 04:10:19 statService: started.
12/1/17 04:10:19 timeSync: service started.
12/1/17 04:10:19 WiFi connected. SSID: Dan, IP: 10.1.1.26
12/1/17 04:10:24 EmonService: started.url: emoncms.org:80, node: IotaWatt, post interval: 10, encrypted POST
12/1/17 04:10:24 EmonService: Start posting from 1511414770
12/1/17 04:10:31 EmonService: POST failed. HTTP code:read Timeout
12/1/17 04:11:31 EmonService: Resending EmonCMS data:2
12/1/17 04:13:32 EmonService: Resending EmonCMS data:3
12/1/17 04:16:33 EmonService: Resending EmonCMS data:4
12/1/17 04:20:34 EmonService: Resending EmonCMS data:5
12/1/17 04:25:35 EmonService: Resending EmonCMS data:6
12/1/17 04:31:36 EmonService: Resending EmonCMS data:7
12/1/17 04:38:37 EmonService: Resending EmonCMS data:8
12/1/17 04:46:38 EmonService: Resending EmonCMS data:9
12/1/17 04:55:39 EmonService: Resending EmonCMS data:10
12/1/17 04:55:40 EmonService: Unable to post to Emoncms after 10 retries. Restarting ESP.
** Restart **
11/30/17 18:55:42 Real Time Clock is running. Unix time: 1512068142
11/30/17 18:55:42 Version: 02_02_24
11/30/17 18:55:42 Reset reason: Software/System restart
11/30/17 18:55:42 Trace: 99,12,13,14,15,16,17,18,13,14,15,16,17,18,13,14,15,30,37,38,148,149,140,142,143,144,145,148,149,146,147,39
11/30/17 18:55:42 ESP8266 ChipID:3134734
12/1/17 04:55:42 device name: IotaWatt, version: 3
12/1/17 04:55:42 Local time zone: 10
12/1/17 04:55:45 Connecting with WiFiManager.
12/1/17 04:55:46 MDNS responder started
12/1/17 04:55:46 You can now connect to http://IotaWatt.local
12/1/17 04:55:46 HTTP server started
12/1/17 04:55:46 dataLog: service started.
12/1/17 04:55:46 dataLog: Last log entry:1512068135
12/1/17 04:55:46 statService: started.
12/1/17 04:55:46 timeSync: service started.
12/1/17 04:55:46 WiFi connected. SSID: Dan, IP: 10.1.1.26
12/1/17 04:55:51 EmonService: started.url: emoncms.org:80, node: IotaWatt, post interval: 10, encrypted POST
12/1/17 04:55:51 EmonService: Start posting from 1511414770
12/1/17 04:55:58 EmonService: POST failed. HTTP code:read Timeout
12/1/17 04:56:58 EmonService: Resending EmonCMS data:2
12/1/17 04:58:59 EmonService: Resending EmonCMS data:3
12/1/17 05:02:00 EmonService: Resending EmonCMS data:4
12/1/17 05:06:01 EmonService: Resending EmonCMS data:5
12/1/17 05:11:02 EmonService: Resending EmonCMS data:6
12/1/17 05:17:03 EmonService: Resending EmonCMS data:7
12/1/17 05:24:04 EmonService: Resending EmonCMS data:8
12/1/17 05:32:05 EmonService: Resending EmonCMS data:9
12/1/17 05:41:06 EmonService: Resending EmonCMS data:10
12/1/17 05:41:07 EmonService: Unable to post to Emoncms after 10 retries. Restarting ESP.
** Restart **
11/30/17 19:41:08 Real Time Clock is running. Unix time: 1512070868
11/30/17 19:41:08 Version: 02_02_24
11/30/17 19:41:08 Reset reason: Software/System restart
11/30/17 19:41:08 Trace: 88,12,13,14,15,16,17,18,13,14,15,16,17,18,13,14,15,30,37,38,148,149,140,142,143,144,145,148,149,146,147,39
11/30/17 19:41:08 ESP8266 ChipID:3134734
12/1/17 05:41:08 device name: IotaWatt, version: 3
12/1/17 05:41:08 Local time zone: 10
12/1/17 05:41:11 Connecting with WiFiManager.
12/1/17 05:41:12 MDNS responder started
12/1/17 05:41:12 You can now connect to http://IotaWatt.local
12/1/17 05:41:12 HTTP server started
12/1/17 05:41:12 dataLog: service started.
12/1/17 05:41:12 dataLog: Last log entry:1512070865
12/1/17 05:41:12 statService: started.
12/1/17 05:41:12 timeSync: service started.
12/1/17 05:41:12 WiFi connected. SSID: Dan, IP: 10.1.1.26
12/1/17 05:41:17 EmonService: started.url: emoncms.org:80, node: IotaWatt, post interval: 10, encrypted POST
12/1/17 05:41:17 EmonService: Start posting from 1511414770
12/1/17 05:41:24 EmonService: POST failed. HTTP code:read Timeout
12/1/17 05:42:24 EmonService: Resending EmonCMS data:2
12/1/17 05:44:25 EmonService: Resending EmonCMS data:3
12/1/17 05:47:26 EmonService: Resending EmonCMS data:4
12/1/17 05:51:27 EmonService: Resending EmonCMS data:5
12/1/17 05:56:28 EmonService: Resending EmonCMS data:6
12/1/17 06:02:29 EmonService: Resending EmonCMS data:7
12/1/17 06:09:30 EmonService: Resending EmonCMS data:8
12/1/17 06:17:31 EmonService: Resending EmonCMS data:9
12/1/17 06:26:32 EmonService: Resending EmonCMS data:10
12/1/17 06:26:33 EmonService: Unable to post to Emoncms after 10 retries. Restarting ESP.
** Restart **
11/30/17 20:26:35 Real Time Clock is running. Unix time: 1512073595
11/30/17 20:26:35 Version: 02_02_24
11/30/17 20:26:35 Reset reason: Software/System restart
11/30/17 20:26:35 Trace: 99,12,13,14,15,16,17,18,13,14,15,16,17,18,13,14,15,30,37,38,148,149,140,142,143,144,145,148,149,146,147,39
11/30/17 20:26:35 ESP8266 ChipID:3134734
12/1/17 06:26:35 device name: IotaWatt, version: 3
12/1/17 06:26:35 Local time zone: 10
12/1/17 06:26:38 Connecting with WiFiManager.
12/1/17 06:26:44 MDNS responder started
12/1/17 06:26:44 You can now connect to http://IotaWatt.local
12/1/17 06:26:44 HTTP server started
12/1/17 06:26:44 dataLog: service started.
12/1/17 06:26:44 dataLog: Last log entry:1512073590
12/1/17 06:26:44 statService: started.
12/1/17 06:26:44 timeSync: service started.
12/1/17 06:26:44 WiFi connected. SSID: Dan, IP: 10.1.1.26
12/1/17 06:26:49 EmonService: started.url: emoncms.org:80, node: IotaWatt, post interval: 10, encrypted POST
12/1/17 06:26:49 EmonService: Start posting from 1511414770
12/1/17 06:26:56 EmonService: POST failed. HTTP code:read Timeout
12/1/17 06:27:56 EmonService: Resending EmonCMS data:2
12/1/17 06:29:57 EmonService: Resending EmonCMS data:3
12/1/17 06:32:58 EmonService: Resending EmonCMS data:4
12/1/17 06:36:59 EmonService: Resending EmonCMS data:5
12/1/17 06:42:00 EmonService: Resending EmonCMS data:6
12/1/17 06:48:01 EmonService: Resending EmonCMS data:7
12/1/17 06:55:02 EmonService: Resending EmonCMS data:8
12/1/17 07:03:03 EmonService: Resending EmonCMS data:9
12/1/17 07:12:04 EmonService: Resending EmonCMS data:10
12/1/17 07:12:05 EmonService: Unable to post to Emoncms after 10 retries. Restarting ESP.
** Restart **
11/30/17 21:12:07 Real Time Clock is running. Unix time: 1512076327
11/30/17 21:12:07 Version: 02_02_24
11/30/17 21:12:07 Reset reason: Software/System restart
11/30/17 21:12:07 Trace: 99,12,13,14,15,16,17,18,13,14,15,16,17,18,13,14,15,30,37,38,148,149,140,142,143,144,145,148,149,146,147,39
11/30/17 21:12:07 ESP8266 ChipID:3134734
12/1/17 07:12:07 device name: IotaWatt, version: 3
12/1/17 07:12:07 Local time zone: 10
12/1/17 07:12:10 Connecting with WiFiManager.
12/1/17 07:12:12 checkUpdate: Invalid response from server.
12/1/17 07:12:12 MDNS responder started
12/1/17 07:12:12 You can now connect to http://IotaWatt.local
12/1/17 07:12:12 HTTP server started
12/1/17 07:12:12 dataLog: service started.
12/1/17 07:12:12 dataLog: Last log entry:1512076320
12/1/17 07:12:12 statService: started.
12/1/17 07:12:12 timeSync: service started.
12/1/17 07:12:13 WiFi connected. SSID: Dan, IP: 10.1.1.26
12/1/17 07:12:17 EmonService: started.url: emoncms.org:80, node: IotaWatt, post interval: 10, encrypted POST
12/1/17 07:12:17 EmonService: Start posting from 1511414770
12/1/17 07:12:24 EmonService: POST failed. HTTP code:read Timeout
12/1/17 07:13:24 EmonService: Resending EmonCMS data:2
12/1/17 07:15:25 EmonService: Resending EmonCMS data:3
12/1/17 07:18:26 EmonService: Resending EmonCMS data:4
12/1/17 07:22:27 EmonService: Resending EmonCMS data:5
12/1/17 07:27:28 EmonService: Resending EmonCMS data:6
12/1/17 07:33:29 EmonService: Resending EmonCMS data:7
