New user to emonpi and the ecosystem - loving it so far.
I want to get SBFspot running on my emonPi so I can retire an old v1 Raspberry pi that been running SBFspot for nearly 7 years! I’ve added an external bluetooth USB adaptor and it can see the inverter.
I’m getting some errors during installation of SBFspot that I cannot google around:
tar: Update_340_SQLite.sql: Cannot write: No space left on device
tar: Exiting with failure status due to previous errors
Unable to untar sbfspot-sqlite-arm-linux-buster.tar.gz
Not entirely convinced it’s out of space:
Filesystem Size Used Avail Use% Mounted on
/dev/root 4.1G 2.1G 1.9G 52% /
devtmpfs 431M 0 431M 0% /dev
tmpfs 463M 0 463M 0% /dev/shm
tmpfs 463M 47M 417M 11% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 463M 0 463M 0% /sys/fs/cgroup
tmpfs 1.0M 1.0M 0 100% /var/tmp
tmpfs 30M 0 30M 0% /tmp
tmpfs 1.0M 0 1.0M 0% /var/lib/php/sessions
/dev/mmcblk0p3 9.9G 8.0M 9.4G 1% /var/opt/emoncms
/dev/mmcblk0p1 253M 54M 199M 22% /boot
log2ram 50M 4.9M 46M 10% /var/log
tmpfs 93M 0 93M 0% /run/user/1000
Any advice on what I can try?
Thanks!
Formatted text - BT, Moderator.
