I’ve just flashed emonSD-07Nov16 RELEASE on my Rasperry Pi 2.
I would like to integrate homie-ota a OTA “server” for Homie-ESP8266 framework for ESP8266 modules , I tried to follow the install step by step instructions but checking the log with
journalctl -f -u homie-ota@hota
I obtain this output
Dec 08 21:26:12 emonpi python[810]: IOError: [Errno 30] Read-only file system: '/home/hota/homie-ota/homie-ota/homie-ota.log'
Dec 08 21:26:12 emonpi systemd[1]: [email protected]: main process exited, code=exited, status=1/FAILURE
Dec 08 21:26:12 emonpi systemd[1]: Unit [email protected] entered failed state.
the “Read-only file system” on the first line :…I think the problem is due to the fact that the system user hota is trying to write in the readonly partition.
Thank you
I’m sure I’m doing something wrong (I’m sorry but I have a very little experience with Linux).
I’ve moved sudo mv home/hota/ home/pi/data/hota
then Rebooted.
Now no more read only error
but it fails
Dec 09 09:48:35 emonpi systemd[1]: Starting Homie OTA...
Dec 09 09:48:35 emonpi systemd[1]: Started Homie OTA.
Dec 09 09:48:37 emonpi systemd[1]: [email protected]: main process exited, code=exited, status=2/INVALIDARGUMENT
Dec 09 09:48:37 emonpi systemd[1]: Unit [email protected] entered failed state
and the status is
pi@emonpi(ro):~$ sudo systemctl status homie-ota@hota
● [email protected] - Homie OTA
Loaded: loaded (/lib/systemd/system/[email protected]; enabled)
Active: failed (Result: exit-code) since Fri 2016-12-09 09:48:37 UTC; 1min 42s ago
Process: 811 ExecStart=/home/pi/data/hota/hota/.venvs/homie-ota/bin/python /home/pi/data/hota/homie-ota/homie-ota/homie-ota.py (code=exited, status=2)
Main PID: 811 (code=exited, status=2)
at the same time MQTT server connection refused (from homie-ota.log): 2016-12-09 11:22:12,518 ERROR Cannot connect to MQTT broker at localhost:1883: [Errno 111] Connection refused
But if I manually start the service with sudo systemctl start homie-ota@hota
It’s ok, infact checking the status the output is
Active: active (running) since Fri 2016-12-09 09:54:16 UTC; 3s ago
Main PID: 4466 (python)
CGroup: /system.slice/system-homie\x2dota.slice/[email protected]
└─4466 /home/pi/data/hota/hota/.venvs/homie-ota/bin/python /home/pi/data/hota/homie-ota/homie-ota/homie-ota.py
