Inputs from local install not showing on emoncms.org
So i’m setting up a new local Pi3 with heatpump HAT.
All the inputs data is showing on there from temp probes, SDM120 and heat meter, cool.
I also have a cloud VM running emomcms which the inputs data is instantly popping up in via the usual send method listed below.
But I can’t see the inputs in emoncms.org, they just don’t appear.
I already have a emonpi/emomtx onsite and all the data from that has been going over to emoncms.org for years. So this confirms the apikey etc as i’ve copy/pasted it.
[[emoncmsorg]]
    [[[init_settings]]]
    [[[runtimesettings]]]
        pubchannels = ToRFM12,
        subchannels = ToEmonCMS,
        url = https://emoncms.org
        apikey = xxxxxxx
        senddata = 1                    # Enable sending data to Emoncms.org
        sendstatus = 0                  # Enable sending WAN IP to Emoncms.org MyIP > https://emoncms.org/myip/list
        sendinterval= 30                # Bulk send interval to Emoncms.org in seconds
[[heatpumpmon-cloud-server]]
    [[[init_settings]]]
        url = http://x.x.x.x/
        apikey = xxxxxxx
        senddata = 1                    # my-awesome-emoncms-server
        sendstatus = 0                  # Enable sending WAN IP to Emoncms MyIP
        sendinterval= 30                # Bulk send interval to post in seconds
I’ve tried changing the nodenames of my SDM120, temp probes and heat meter on the local HAT.
Removed underscores, removed hyphens, all the nodenames are unique on the HAT install.
No matter what I do, the inputs appear instantly on the cloud VM, but I see nothing on emoncms.org despite the log on the local HAT saying things have been sent to emoncms.org
2022-10-12 08:29:15,332 DEBUG    emoncmsorg Buffer size: 9
2022-10-12 08:29:15,334 INFO     emoncmsorg sending: https://emoncms.org/input/bulk.json? data=[[1665559730.0808098,"heatpumpmon-temps",19.25],[1665559730.081241,"heatpumpmonsharky",0,0,0,0,0,0,0,0,0,24.6,26.1,-1.5,0],[1665559730.0609334,"heatpumpmon-sdm120",238.7,0.158,8.8,33.7,0.267,50,14.329,0,0.484],[1665559740.077316,"heatpumpmon-temps",19.25],[1665559740.0363603,"heatpumpmonsharky",0,0,0,0,0,0,0,0,0,24.6,26.1,-1.5,0],[1665559740.0074573,"heatpumpmon-sdm120",238.6,0.157,8.7,33.5,0.261,50,14.329,0,0.484],[1665559750.066636,"heatpumpmon-temps",19.25],[1665559750.0014844,"heatpumpmonsharky",0,0,0,0,0,0,0,0,0,24.6,26.1,-1.5,0],[1665559750.0631785,"heatpumpmon-sdm120",238.6,0.157,8.8,33.7,0.263,50.04,14.329,0,0.484]]&sentat=1665559755&apikey=E-M-O-N-C-M-S-A-P-I-K-E-Y
2022-10-12 08:29:15,502 DEBUG    emoncmsorg acknowledged receipt with 'ok' from https://emoncms.org
If you’ve played around with emoncms and fiddled for so long, can your emoncms.org account get its knickers in a twist?
Does it need a bit of clean up and flush?
Any thoughts or tips would be very much appreciated.
Cheers, Mick
Hello @Zarch
Sorry about this, looking into this I realise the issue is being caused by node names being longer than 16 characters e.g: heatpumpmonsharky is 17.
I appreciate the response from emoncms was not particularly helpful!
I’ve changed the implementation now to clip the name rather than discard it completely.
You may want to shorten the names to something like hpmonsharky to improve readability?
That’s awesome, thanks for tracking that down.
I will reduce my input names char length.
:+1:
