Is the 1.65 / 2.5 V centre rail correct? Is the op-amp oscillating?
286 V rather than 240 V is probably only a calibration problem - is it relatively steady? Where does the voltage come from and have you used the divider on your circuit diagram?
What c.t are you using, and what is its calibration factor?
Are you using your own sketch, or one of ours. If so, which?
To be honest, this is heading for “stupid question” territory because you’re asking for help but not giving enough background information to allow me or anybody to work out what the real fault might be and to rule out a whole host of other possible causes.
