It has only lost it’s formatting because of the way the documents are currently displayed via the oem site. if you checkout the raw file on github it’s fine. (See forum-archive/ical_tool.html at master · openenergymonitor/forum-archive · GitHub)
// ical_tool - calculates current scale factor (ICAL) for emonTx from OpenEnergyMonitor
// Martin Roberts 26/02/13
// requires an optical meter pulse sensor and the PLL50Hz library
// default calibration values
#define VCAL 237.9 // 240:11.2 for transformer x 11:1 for resistor divider
#define ICAL 111.1 // 100A:0.05A for transformer / 18 Ohms for resistor
#define ILEAD 200.0 // time in microseconds that current leads voltage by
// other system constants
#define LOOPCYCLES 250 // number of mains cycles for outer loop, also time between radio transmissions
#define POWER_VOLTS 3.3 // used here because it's more accurate than the internal band-gap reference
#define SUPPLY_FREQUENCY 50
#define JOULES_PER_PULSE 3600.0 // number of Joules per meter pulse, 1Wh = 3600 Joules
#define PULSES_PER_CALC 10 // number of meter pulses accumulated before calculations are done
// constants calculated at compile time
#define LOOPSAMPLES (LOOPCYCLES * NUMSAMPLES)
// Arduino I/O pin useage
#define LEDPIN 9
#define PULSEPIN 7 // pin for meter pulse detector (0-7 only) (3 is used by PLL50Hz library)
#include <PLL50Hz.h>
float Vrms,I1rms,I2rms,frequency;
long totalV1squared,totalV2squared,totalI1squared,totalI2squared,totalP1,totalP2;
long sumTimerCount;
float realPower1,apparentPower1,powerFactor1;
float realPower2,apparentPower2,powerFactor2;
word cycleCount;
boolean showCT2;
float expectedEnergyPerPulse;
long energyAccumulator,pulseEnergyAccumulator;
char pulseCount;
boolean calibrating;
float Vratio,I1ratio,I2ratio;
CycleData cd;
void setup()
Serial.begin(9600);
pinMode(LEDPIN, OUTPUT);
digitalWrite(LEDPIN, HIGH);
PLL.begin(&cd);
// set calibration to default values
PLL.updatePhaseShift((int)(ILEAD*16),false);
PLL.updatePhaseShift((int)(ILEAD*16),true);
Vratio=(VCAL * POWER_VOLTS)/1024;
I1ratio=(ICAL * POWER_VOLTS)/1024;
I2ratio=(ICAL * POWER_VOLTS)/1024;
bitSet(PCMSK2,PULSEPIN); // unmask pin change interrupt for pulse detector
showHelp();
void loop()
if(PLL.newCycle) addCycle(); // a new mains cycle has been sampled
if(calibrating)
calibrate();
return;
if(cycleCount>=LOOPCYCLES)
calculateVIPF();
showResults();
if(Serial.available())
int c=toupper(Serial.read());
switch(c)
case 'H':
case '?': showHelp(); break;
case 'C': calibrating=true; break;
case '1': showCT2=false; break;
case '2': showCT2=true; break;
case 'V': updateVCAL(); break;
case 'D': displayCalVals(); break;
digitalWrite(LEDPIN,digitalRead(PULSEPIN)); // copy pulse input state to LED
// add data for new 50Hz cycle to total
void addCycle()
totalV1squared+=cd.cycleV1squared;
totalV2squared+=cd.cycleV2squared;
totalI1squared+=cd.cycleI1squared;
totalI2squared+=cd.cycleI2squared;
totalP1+=cd.cycleP1;
totalP2+=cd.cycleP2;
sumTimerCount+=(OCR1A+1); // for average frequency calculation
energyAccumulator+=(showCT2?cd.cycleP2:cd.cycleP1);
cycleCount++;
PLL.newCycle=false;
// calculate voltage, current, power and frequency
void calculateVIPF()
float V2rms; // need this because voltage interpolation makes it different from Vrms
Vrms = Vratio * sqrt(((float)totalV1squared)/LOOPSAMPLES);
V2rms = Vratio * sqrt(((float)totalV2squared)/LOOPSAMPLES);
I1rms = I1ratio * sqrt(((float)totalI1squared)/LOOPSAMPLES);
I2rms = I2ratio * sqrt(((float)totalI2squared)/LOOPSAMPLES);
realPower1 = (Vratio * I1ratio * (float)totalP1)/LOOPSAMPLES;
apparentPower1 = Vrms * I1rms;
powerFactor1=abs(realPower1 / apparentPower1);
realPower2 = (Vratio * I2ratio * (float)totalP2)/LOOPSAMPLES;
apparentPower2 = V2rms * I2rms;
powerFactor2=abs(realPower2 / apparentPower2);
frequency=((float)LOOPCYCLES*16000000.0)/((float)sumTimerCount*NUMSAMPLES);
totalV1squared=0;
totalV2squared=0;
totalI1squared=0;
totalI2squared=0;
totalP1=0;
totalP2=0;
cycleCount=0;
sumTimerCount=0;
void showResults()
Serial.print("CT");
Serial.write(showCT2?'2':'1');
Serial.write(' ');
Serial.print("V=");
Serial.print(Vrms);
Serial.print(" I=");
Serial.print(showCT2?I2rms:I1rms);
Serial.print(" RP=");
Serial.print(showCT2?realPower2:realPower1,0);
Serial.print(" AP=");
Serial.print(showCT2?apparentPower2:apparentPower1,0);
Serial.print(" PF=");
Serial.print(showCT2?powerFactor2:powerFactor1,4);
Serial.print(" F=");
Serial.print(frequency);
Serial.println(", 'H' or ? for help");
void calibrate()
static int oldPulseCount;
static boolean initialised=false;
if(!initialised)
Serial.println();
Serial.print("Waiting for meter pulses.");
pulseCount=-2;
oldPulseCount=pulseCount;
pulseEnergyAccumulator=0;
float Iratio=showCT2?I2ratio:I1ratio;
float joulesPerBufferUnit = (Vratio * Iratio)/(SUPPLY_FREQUENCY*NUMSAMPLES);
expectedEnergyPerPulse = JOULES_PER_PULSE/joulesPerBufferUnit;
bitSet(PCICR,PCIE2); // enable pin change interrupt
cycleCount=0;
initialised=true;
return;
if(pulseCount>=PULSES_PER_CALC)
bitClear(PCICR,PCIE2); // disable pin change interrupt
float energyPerPulse=pulseEnergyAccumulator/PULSES_PER_CALC;
Serial.println();
float error=(energyPerPulse-expectedEnergyPerPulse)*100/expectedEnergyPerPulse;
Serial.print("Current error ");
Serial.print(error,1);
Serial.print("% ");
Serial.print("Old ICAL=");
Serial.print(Iratio*1024/POWER_VOLTS);
Iratio*=(expectedEnergyPerPulse/energyPerPulse);
Serial.print(", new ICAL=");
Serial.println(Iratio*1024/POWER_VOLTS);
if(showCT2) I2ratio=Iratio;
else I1ratio=Iratio;
Serial.println();
calculateVIPF(); // to clear accumulators
initialised=false;
calibrating=false;
return;
if(cycleCount>=(30*SUPPLY_FREQUENCY))
Serial.println(" timed out");
Serial.println();
calculateVIPF();
initialised=false;
calibrating=false;
return;
if(pulseCount!=oldPulseCount) Serial.write('.');
ISR(PCINT2_vect)
if(digitalRead(PULSEPIN)==HIGH) return; // we want the falling edge
if(pulseCount>=0) pulseEnergyAccumulator+=energyAccumulator;
pulseCount++;
energyAccumulator=0;
void updateVCAL()
Serial.println();
Serial.print("VCAL");
Serial.write('=');
Serial.print(Vratio*1024/POWER_VOLTS);
Serial.print(" enter new value or 's' to skip ");
while(!Serial.available());
if(toupper(Serial.peek())=='S')
Serial.write(Serial.read());
Serial.println();
return;
float Vcal=Serial.parseFloat();
Serial.println(Vcal);
Vratio= Vcal * POWER_VOLTS/1024;
Serial.println();
void displayCalVals()
Serial.println();
Serial.print("VCAL=");
Serial.println(Vratio*1024/POWER_VOLTS);
Serial.print("I1CAL=");
Serial.println(I1ratio*1024/POWER_VOLTS);
Serial.print("I2CAL=");
Serial.println(I2ratio*1024/POWER_VOLTS);
Serial.println();
void showHelp()
Serial.println();
Serial.println("ical_tool");
Serial.println("H,? - display this Help");
Serial.println("1,2 - display data for CT1/2");
Serial.println("C - Calibrate ICAL");
Serial.println("V - enter new VCAL");
Serial.println("D - Display calibration data");
Serial.println();
[edit - If you follow the link in the first post of this thread and then right click and “view page source” you can see why it’s wrong, the file is not html, even though it has an html extension, it’s raw Arduino/C/C++ code.]
