I can not seem to get kWh accumulator to work. I have attached a screenshot of setup of my feed which was setup following the daily kwh log guide. The idea is to log inverter load to allow me have a log of my electricity usage.
here is what I have done so far.
The input is in watt so I used “Power to kWh” processor to convert it to kWh (is that how it works?)
I then added “kWh Accumulator” as the 3rd processor to take from Power to kWh processor. The screenshot below gives an illustration
Unfortunately this does not seem to work. The kWh feed is always reading 0.00 (See attached for the csv output of the feed
graph.csv (11.2 KB)
This is 3 day since I set up the feed and got nothing. I have tried to rack my brains on what I could be doing wrong but for the live of me I can not seem to find out. This is not my first time doing this so I don’t know what I could be doing wrong.
Below is my server information
Server Information
Server Information
Services
redis-server :- Active Running
service-runner :- Active Running
emonhub :- Not found or not installed
emoncms_mqtt :- Not found or not installed
feedwriter :- Not found or not installed
emonPiLCD :- Not found or not installed
mosquitto :- Not found or not installed
demandshaper :- Not found or not installed
Emoncms
Version :- 11.0.5
Git :-
Components :- Emoncms Core v11.0.5 | App v2.3.4 | Backup v2.3.2 | Dashboard v2.1.5 | Device v2.1.3 | Graph v2.1.1 | EmonScripts v1.3.9
Server
Machine :- Standard PC (Q35 + ICH9, 2009), BIOS rel-1.12.1-0-ga5cab58e9a3f-prebuilt.qemu.org 04/01/2014
CPU :- 1 Threads(s) | 1 Core(s) | 1 Sockets(s) | AMD EPYC 7601 32-Core Processor | 2199.998MHz | 4399.99MIPS |
OS :- Linux 4.19.0-20-amd64
Host :- localhost | localhost | (172.104.130.37)
Date :- 2022-04-22 03:33:26 WAT
Uptime :- 03:33:26 up 5 days, 11:29, 1 user, load average: 0.00, 0.03, 0.00
Memory
RAM :- Used: 63.39%
Total :- 987.2 MB
Used :- 625.76 MB
Free :- 361.44 MB
Swap :- Used: 23.78%
Total :- 512 MB
Used :- 121.75 MB
Free :- 390.25 MB
Disk
- **** :- - / :- Used: 43.47%
Total :- 24.11 GB
Used :- 10.48 GB
Free :- 12.39 GB
Read Load :- 501.42 B/s
Write Load :- 13.84 KB/s
Load Time :- 10 mins
HTTP
Server :- Apache/2.4.38 (Debian) HTTP/1.1 CGI/1.1 8080
MySQL
Version :- 5.5.5-10.3.34-MariaDB-0+deb10u1
Host :- localhost (127.0.0.1)
Date :- 2022-04-22 02:33:26 (UTC 00:00)
Stats :- Uptime: 473390 Threads: 14 Questions: 1023065 Slow queries: 0 Opens: 28 Flush tables: 1 Open tables: 21 Queries per second avg: 2.161
Redis
Version :-
Redis Server :- 5.0.14
PHP Redis :- 5.3.4
Host :- localhost:6379
Size :- 305 keys (916.41K)
Uptime :- 5 days
PHP
Version :- 7.3.31-1~deb10u1 (Zend Version 3.3.31)
Run user :- User: www-data Group: www-data Script Owner: root
Modules :- apache2handlercalendar Core ctype curl date dom v20031129exif fileinfo filter ftp gettext hash iconv json v1.7.0libxml mbstring mysqli mysqlnd vmysqlnd 5.0.12-dev - 20150407 - $Id: 7cc7cc96e675f6d72e5cf0f267f48e167c2abb23 $openssl pcre PDO pdo_mysql Phar posix readline redis v5.3.4Reflection session shmop SimpleXML sockets sodium SPL standard sysvmsg sysvsem sysvshm tokenizer wddx xml xmlreader xmlwriter xsl Zend OPcache zlib
Client Information
Client Information
HTTP
Browser :- Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:99.0) Gecko/20100101 Firefox/99.0
Language :- en-US,en;q=0.5
Window
Screen
Resolution :- 1728 x 1117
Hello @Thomas_Adeyinka The power to kWh process records cumulative kWh directly, there’s no need for the kWh accumulator process in this context. I appreciate it might not be that clear.
Thanks @TrystanLea I guess my next question then would be. What is the use of the kWh accumulator? and how does it differ from Power to kWh?
I basically want a way to log daily, weekly, monthly and Yearly energy data. Can I achieve this with the Power to kWh? Before now I use to think I needed kWh accumulator for that.
cefoster0
(Chris Foster)
4
I’m in the same boat. Using online server and the “power and kWh/d” feature and no graph or anything. I really want to see daily cumulative measure using the iOS widget or a visualization.
