Im trying to post data from a dht22 to my emoncms server. I was able to post a single value with http post but when I try two values it fails. And when I try http get it fails. Here are the codes and results in the Serial Monitor:
Http Post successful with 1 parameter, Temp:
void start_test () {
//For DHT22 Grove Pro
float h = dht.readHumidity();
float t = dht.readTemperature();
dtostrf(t, 4, 2, dataString); //convert flat to char
Serial.println(dataString);
}void httppost () {
esp.println(“AT+CIPSTART=“TCP”,”" + server + “”,80");//start a TCP connection.
if( esp.find(“OK”)) {
Serial.println(“TCP connection ready”);
}// //CODE USED TO BUILD COMPLETE STRING
String nodeData=“node=fortnite&data={“a”:”;
String nodeWithJson=nodeData + dataString + “}”; //COMBINE STRING OBJECT WITH CHAR[]
String apiKeyString="&apikey=";
apiKeyString.concat(EMON_APIKEY); //JOIN PARAMETER LITERAL STRING => String Object
String finalData=nodeWithJson+apiKeyString; //COMBINE BOTH PREVIOUS STRING OBJECTS
Serial.println(“finalData”);
Serial.println(finalData);
delay(1000);
String postRequest=“POST " + uri + " HTTP/1.1\r\n”+“Host: " + server + “\r\n” + “Accept: " + “/” + "\r\n”+“Content-Length: " + finalData.length() + “\r\n” + “Content-Type: application/x-www-form-urlencoded\r\n”+”\r\n” + finalData;
Serial.println(“postRequest”);
Serial.println(postRequest);
…more code
This is the Post Request:
&node=fortnite&data={"a":28.00}&apikey=mykey
And I get http 200 OK.
This is the Post code that fails with a second parameter, Humidity:
dtostrf(t, 4, 2, tempString); //convert flat to char
dtostrf(h, 4, 2, humString); //convert flat to char
strcpy(dataString,tempString);
strcat(dataString,humString);
}void httppost () {
String nodeData1="&node=fortnite&data={“t”:";
String nodeData2=nodeData1 + tempString;
String nodeData3=nodeData2 + “,“h”:”;
String nodeData4=nodeData3 + humString;
String nodeData5=nodeData4 + “}”;
String finalData=nodeData5+apiKeyString; //COMBINE BOTH PREVIOUS STRING OBJECTS
Serial.println(finalData.length());
delay(1000);
…more code
&node=fortnite&data={"t":28.40,"h":69.20}&apikey=mykey
2.b I even tried the url directly and it works fine:
http://santiapps.com/emoncms/input/post?node=fortnite&data={"t":26.60,"h":49.70}&apikey=mykey
Here is the image of it in my browser
3. I tried this GET request also but it returns a 400 http error:
#include "SoftwareSerial.h"
#include "DHT.h"
#define DHTPIN A1 // what pin we're connected to
#define DHTTYPE DHT22 // DHT 22 (AM2302)
DHT dht(DHTPIN, DHTTYPE);
String ssid ="myssid";
String password="mypwd";
String server = "santiapps.com"; // www.example.com
String uri = "/emoncms/input/post";
#define EMON_APIKEY F("mykey")
byte dat [5];
String temp ,hum;
String data;
char dataString[20];
char tempString[20];
char humString[20];
SoftwareSerial esp(6, 7);// RX, TX
void setup() {
esp.begin(9600);
Serial.begin(9600);
Serial.println("setup");
reset();
connectWifi();
void reset() {
Serial.println("reset");
esp.println("AT+RST");
delay(1000);
if(esp.find("OK") ) Serial.println("Module Reset");
void connectWifi() {
Serial.println("connect to wifi");
String cmd = "AT+CWJAP=\"" +ssid+"\",\"" + password + "\"";
esp.println(cmd);
delay(400);
while (esp.available()){
String inData = esp.readStringUntil('\n');
Serial.println("Got reponse from ESP8266: " + inData);
if(esp.find("OK")) {
Serial.println("Connected!");
} else {
connectWifi();
Serial.println("Cannot connect to wifi"); }
void loop(){
Serial.println("loop");
start_test();
httppost();
delay(100000);//100k ms = 100s or ~ 1.8m
void httppost () {
esp.println("AT+CIPSTART=\"TCP\",\"" + server + "\",80");//start a TCP connection.
if( esp.find("OK")) {
Serial.println("TCP connection ready");
String nodeData1="/emoncms/input/post.json?node=fortnite&json={\"t\":";
String nodeData3=nodeData2 + ",\"h\":";
String nodeData5=nodeData4 + "}";
delay(1000);
String getRequest="GET " + finalData + " HTTP/1.0\r\n"+"Host: " + server + "\r\n" + "Connection: keep-alive\r\n\r\n";
String requestLength = String(getRequest.length());
Serial.println("getRequest");
Serial.println(getRequest);
String sendCmd = "AT+CIPSEND=";//determine the number of caracters to be sent.
esp.print(sendCmd);
esp.println(requestLength);
delay(1000);
if(esp.find(">")) {
Serial.println("Sending..");
esp.print(getRequest);
if(esp.find("SEND OK")) {
Serial.println("Packet sent");
while (esp.available()) {
String tmpResp = esp.readString();
Serial.println(tmpResp);
// close the connection
esp.println("AT+CIPCLOSE");
And here is the get request:
setup
reset
connect to wifi
Got reponse from ESP8266: AT+CWJAP="myssid","mypwd"
Got reponse from ESP8266: WIFI DISCONNEC
connect to wifi
Got reponse from ESP8266: busy p...
Connected!
loop
29.5051.60
/emoncms/input/post.json?node=fortnite&json={"t":29.50,"h":51.60}&apikey=mykey
getRequest
HTTP/1.0
Host: santiapps.com
Sending..
Packet sent
+IPD,311:HTTP/1.1 400 Bad Request
Server: nginx
Date: Mon, 08 Oct 2018 02:00:11 GMT
C
Im not sure what is wrong with the post or get request that is making those fail.
