Hi @emrys, I found your explanatory post very helpful being unaware of the behind-the-scenes validation that is required to mitigate against malicious code. Looking at your 2nd reply, I guess that the next stage is to gain approval to get the fix into the master branch of the emoncms code. Presumably it can then be rolled out at the next periodic update to emoncms on the Admin page. Hopefully there will be no more HTML extended characters that will require this type of manual intervention. :smile:
