This is a simple howto for people who are setting up an IoT device with WiFi connectivity ( ie emontx with esp module ) on a cheap orange Pi pc plus that is wifi capable. I have all my IoT devices communicating directly to my orange Pi. I originally had it going through my router, but with thousands of requests per minute from several IoT devices at once, it would impact the performance of the router - so I removed the router from the equation. In the end it works much better and smoother with fewer lost packets, and I have the IoT device connecting to the unit from a couple of hundred meters away. It also isolates my IoT from direct access to the network, reducing the possibility of hacking my units externally.
installed – hostapd and dsnmasq
modify to your preferences
/etc/network/interface
# Local loopback
auto lo eth0 wlan0
iface lo inet loopback
# Wired adapter #1
allow-hotplug eth0
#no-auto-down eth0
iface eth0 inet dhcp
# hwaddress ether # if you want to set MAC manually
# pre-up /sbin/ifconfig eth0 mtu 3838 # setting MTU for DHCP, static just: mtu 3838
# Wired adapter #2
#allow-hotplug eth1
#iface eth1 inet dhcp
# Wireless adapter #1
iface wlan0 inet static
hostapd /etc/hostapd.conf
address 192.168.50.1
netmask 255.255.255.0
broadcast 255.255.255.255
network 192.168.50.0
# wpa-ssid SSID
# wpa-psk xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
# to generate proper encrypted key: wpa_passphrase yourSSID yourpassword
/etc/hostapd.conf
interface=wlan0
ssid=IOT
channel=1
/etc/networkmanager/networkmanager.conf
[main]
dns=dnsmasq
plugins=ifupdown,keyfile
[ifupdown]
managed=true
[keyfile]
unmanaged-devices=interface-name:p2p0
unmanaged-devices=interface-name:wlan0
/etc/dnsmasq.conf ( added these lines)
interface=lo,wlan0
no-dhcp-interface=lo
dhcp-range=192.168.50.20,192.168.50.254,255.255.255.0,12h
/etc/sysctl.conf (added this line )
net.ipv4.ip_forward=1
/etc/rc.local ( added this line)
iptables -t nat -A POSTROUTING -s 192.168.50.0/24 ! -d 192.168.50.0/24 -j MASQUERADE
I hope this helps someone set up their project a bit easier than searching multiple websites for the info.
