I have an Iotawatt feeding data to emoncms. We have a split phase system where phase one feeds the house and has the PV system onit, and phase two has all the outbuildings. I have CT clamps on both phases reading import/export on phase one and import on phase two.
With Mysolar, it takes the import and export from phase one but I would like to add the import from phase two to give an accurate view of my total grid import use. Could someone check my feed setups please to make sure I’ve configured this correctly. Thanks.
Basically, you can add some extra steps to combine one input with another, and generate an extra feed. This achieves the same as the virtual feed.
It can get a bit messy having several different processing flows in one big stack, e.g. log to feed, log to kwh feed, combine with two other arrays and log to feed, log to combined kwh, generate an import-only (ignore negatives) feed, generate an export-only (ignore positives) feed etc. Just remember you can use “Reset to Original” to start another flow, like this:
I started my own local instance of emoncms because my feed count was getting high, and even at £1 per feed per year it was going to get pricey.
Hi Tom, sorry for the delay, I’ve been away for a week or two. Thanks for the info, like you I think I’ll be looking at a local instance of emoncms in the near future, currently considering whether to buy a pi just for that or create a vm on my old Mac mini which I use as a print and media server connected to a NAS.
Not that I know much about it, but setting up emonCMS on anything other than a Pi can be quite tricky according to people who have reported their experience here. If a RPi is available, then that’s by far the easiest - just flash the emonPi image to an SD card.
No bother - I only caught this update because I am messing about before starting work!
I’ve got it running on a RasPi pinched from my 3d printer, but at some point I want to migrate EmonCMS and a load of other random services off the RasPis and onto a small intel PC of some sort, just for simplicity…
yes, I was thinking the same, why have several Pi’s running different things when a small pc or Mac could run them all on different instances. Looks like more research is needed.
