Hello,
I’m currently on: low-write 10.1.4-beta. I would like to upgrade to the latest Stable version but am not sure how to switch from Beta to Stable. It was explained to me in the past (that’s how I got to Beta) but I’ve forgotten how.
Thanks,
Neil
Server Information
Server Information
Services
  • emonhub :- Active Running
  • emoncms_mqtt :- Active Running
  • feedwriter :- Active Running - sleep 60s 27 feed points pending write
  • service-runner :- Active Running
  • emonPiLCD :- Active Running
  • redis-server :- Active Running
  • mosquitto :- Active Running
Emoncms
Server
  • OS :- Linux 4.14.71-v7+
  • Host :- emonpi | emonpi | (192.168.1.11)
  • Date :- 2020-02-20 06:54:42 EST
  • Uptime :- 06:54:42 up 4 days, 16:42, 0 users, load average: 0.58, 0.26, 0.18
Memory
  • RAM :- Used: 30.63%
    • Total :- 976.74 MB
    • Used :- 299.14 MB
    • Free :- 677.6 MB
  • Swap :- Used: 0.00%
    • Total :- 100 MB
    • Used :- 0 B
    • Free :- 100 MB
Disk
  • / :- Used: 42.93%
    • Total :- 3.81 GB
    • Used :- 1.64 GB
    • Free :- 2 GB
  • /boot :- Used: 51.72%
    • Total :- 42.52 MB
    • Used :- 21.99 MB
    • Free :- 20.53 MB
  • /home/pi/data :- Used: 2.41%
    • Total :- 10.32 GB
    • Used :- 254.61 MB
    • Free :- 9.54 GB
  • /mnt/usbdrive :- Used: 0.59%
    • Total :- 28.97 GB
    • Used :- 176.07 MB
    • Free :- 27.3 GB
HTTP
  • Server :- Apache/2.4.25 (Raspbian) HTTP/1.1 CGI/1.1 80
MySQL
  • Version :- 5.5.5-10.1.23-MariaDB-9+deb9u1
  • Host :- localhost:6379 (127.0.0.1)
  • Date :- 2020-02-20 06:54:42 (UTC -05:00‌​)
  • Stats :- Uptime: 409020 Threads: 3 Questions: 1319051 Slow queries: 0 Opens: 50 Flush tables: 1 Open tables: 40 Queries per second avg: 3.224
Redis
  • Version :- 3.2.6
  • Size :- 254 keys (809.62K)
  • Uptime :- 4 days
MQTT Server
  • Version :- Mosquitto 1.4.10
  • Host :- localhost:1883 (127.0.0.1)
PHP
  • Version :- 7.0.30-0+deb9u1 (Zend Version 3.0.0)
  • Modules :- apache2handler | calendar v7.0.30-0+deb9u1 | Core v7.0.30-0+deb9u1 | ctype v7.0.30-0+deb9u1 | curl v7.0.30-0+deb9u1 | date v7.0.30-0+deb9u1 | dom v20031129 | exif v7.0.30-0+deb9u1 | fileinfo v1.0.5 | filter v7.0.30-0+deb9u1 | ftp v7.0.30-0+deb9u1 | gd v7.0.30-0+deb9u1 | gettext v7.0.30-0+deb9u1 | hash v1.0 | iconv v7.0.30-0+deb9u1 | igbinary v2.0.1 | json v1.4.0 | libxml v7.0.30-0+deb9u1 | mbstring v7.0.30-0+deb9u1 | mcrypt v7.0.30-0+deb9u1 | mosquitto v0.4.0 | mysqli v7.0.30-0+deb9u1 | mysqlnd vmysqlnd 5.0.12-dev - 20150407 - $Id: b5c5906d452ec590732a93b051f3827e02749b83 $ | openssl v7.0.30-0+deb9u1 | pcre v7.0.30-0+deb9u1 | PDO v7.0.30-0+deb9u1 | pdo_mysql v7.0.30-0+deb9u1 | Phar v2.0.2 | posix v7.0.30-0+deb9u1 | readline v7.0.30-0+deb9u1 | redis v4.1.1 | Reflection v7.0.30-0+deb9u1 | session v7.0.30-0+deb9u1 | shmop v7.0.30-0+deb9u1 | SimpleXML v7.0.30-0+deb9u1 | sockets v7.0.30-0+deb9u1 | SPL v7.0.30-0+deb9u1 | standard v7.0.30-0+deb9u1 | sysvmsg v7.0.30-0+deb9u1 | sysvsem v7.0.30-0+deb9u1 | sysvshm v7.0.30-0+deb9u1 | tokenizer v7.0.30-0+deb9u1 | wddx v7.0.30-0+deb9u1 | xml v7.0.30-0+deb9u1 | xmlreader v7.0.30-0+deb9u1 | xmlwriter v7.0.30-0+deb9u1 | xsl v7.0.30-0+deb9u1 | Zend OPcache v7.0.30-0+deb9u1 | zlib v7.0.30-0+deb9u1
Pi
  • Model :- Raspberry Pi 3 Model B+ Rev 1.3 - 1GB (Sony UK)
  • SoC :- Broadcom BCM2835
  • Serial num. :- 5ABE4EF9
  • Temperature :- 48.31°C - 47.8°C
  • emonpiRelease :- emonSD-30Oct18
  • File-system :- read-write
Client Information
Client Information
HTTP
  • Browser :- Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_3) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/13.0.5 Safari/605.1.15
  • Language :- en-us
Window
  • Size :- 1268 x 798
Screen
  • Resolution :- 1680 x 1050
I’m not at home to check but I think…
cd /var/www/emoncms
git checkout stable
In the Admin page the ‘beta’ should be gone so just run an update from the Admin page.
Check the update log for any errors.
Thanks Brian, exactly what I needed. I’ll update this weekend.
Hello @Brian,
I performed the update yesterday. It seemed to work (for the most part). I get this error message before logging in to emoncms and when the webpage updates. I have to press ‘Close’ several times before I can log in.
Any ideas?
Have you cleared the browser cache?
@Borpin,
I have an instance of EmonCMS embedded in Node-RED. Also, in Node-RED, I had an unused embedded multigraph in a Template node. For some reason this is what caused the error. I deleted the node and the error cleared. When I opened EmonCMS in the web browser (without node-RED) the error did not occur.
I did not find the root cause but it was probably a missing graph or a change in the embedded code.
Bottom line is the upgrade worked :grinning:
Thanks, have a great weekend.
