How do I set up solar PV monitoring with OpenEnergyMonitor?
Hi Everyone, I am Soumitra Dutta an entrepreneur & photographer from Oxford. I’m planning to monitor my solar PV system using OpenEnergyMonitor. I’m unsure about the correct sensor setup and how to configure everything in Emoncms for accurate generation and consumption tracking. What approach worked best for you, and are there any common pitfalls I should avoid?
Regards
Soumitra Dutta
Hi Soumitra,
Welcome to the forum. Here’s our guide on solar PV monitoring: Solar PV — OpenEnergyMonitor 0.0.1 documentation
It was written a while ago so the hardware it refers to will have changed slightly, the principal is the same. You will want to monitor the solar PV generation i.e AC output of the inverter and main supply grid import/export.
The emonPi3 is the easiest way to do this, this is the latest current energy monitoring hardware:
