I had a power cut this mroning when the power came on line I couldn’t connect to the data base. I can ssh to the pi I have set up. The database gave a connection refused error check settings.php. I checked the logs nothing, the dis space looks ok. I reset the paswords in settings.php. I got a blank screen. I edite the default settings file. For some reason localhost doesn’t work I am using 127.0.0.1. I reset the username and password but I am now getting this error.
Can’t connect to database, please verify credentials/configuration in settings.php
Error message: Access denied for user ‘emonpi’@‘localhost’ (using password: YES)
Any ideas?
Richard
