Welcome, Jon, to the OEM forum.
Those must have old versions of emonCMS that are based on obsolete versions of the Raspberry Pi operating system.
My advice would be start again with the present download, which you will be able to update as new capabilities are added. I have the latest stable version running on a Pi 2B, so there’s not likely to be a problem with the hardware, apart from mine is a bit slow creating a big (in time) graph.
While you’re at it, and for the price, it might be a good idea to start with new SD cards, unless you’re sure those haven’t seen any significant use.
None that I’m aware of - I’ve got a lot of those in my Wi-Fi password (courtesy of Keepass’s random generator).
