# HELP - Daikin Configuration WD curve and modulation with a Madoka room thermostat
**URL:** <https://community.openenergymonitor.org/t/help-daikin-configuration-wd-curve-and-modulation-with-a-madoka-room-thermostat/25089>\
**Category:** Heatpump\
**Created:** [14 December 2023 10:08 UTC](https://community.openenergymonitor.org/t/help-daikin-configuration-wd-curve-and-modulation-with-a-madoka-room-thermostat/25089 "2023-12-14T10:08:35Z")\
**Showing post:** 32
**Author:** ![tiger\_cook](https://community.openenergymonitor.org/user_avatar/community.openenergymonitor.org/tiger_cook/32/27858_2.png) [@tiger\_cook](https://community.openenergymonitor.org/u/tiger_cook)\
**Post date:** [18 March 2024 11:30 UTC](https://community.openenergymonitor.org/t/help-daikin-configuration-wd-curve-and-modulation-with-a-madoka-room-thermostat/25089/32 "2024-03-18T11:30:56Z")
I also picked up from another thread, the best and lowest LWT is 31, I did this by setting the offset +2
> [@Pushing for COP 5 on Daikin EDLA08E2V3](https://community.openenergymonitor.org/t/pushing-for-cop-5-on-daikin-edla08e2v3/25446/33):
> Don’t worry, I am on heat pump 2 and in the middle of doing a lot of renovations to the house. I have not set any pump restrictions and you will be able to check this from the export above, all of the codes in the export are listed in the installer reference guide available from Daikin (or Google “Daikin edla04-08ev3 installer reference guide”). My only concern with the lower DT is how the system will perform on cooler days. Hy hope is that as it is in fancoil the system will just let the DT…
_[View the full topic](https://community.openenergymonitor.org/t/help-daikin-configuration-wd-curve-and-modulation-with-a-madoka-room-thermostat/25089)._
