Hello Mark, do you know which version of the EmonESP firmware that you are now running on the ESP module? Is it the latest?
You can erase the configuration completely with the esptool erase flash command, although depending on the version of the firmware you have uploaded there are easier ways, e.g put the jumper on GPIO0 a second after start up or I think the latest should automatically go into AP mode.
