…what’s you Min.target flow temp set to?
…As long as that temp is within min and max settings.
So your min setting has to be lower than for 17 indoors and (0.X on the curve).
Min. target flow temp: 20ºC may be the reason then as it’s higher than the set back. I will adjust and see how we get on. :crossed_fingers:
