Any idea what might be causing this loss of data?
All channels are logging fine.
That’s useful but I was thinking more the inputs page e.g:
Are you using SNXenergy directly to provide Heat_kWh_3 with a ‘log_to_feed’ input process? What do you have setup for the electric consumption?
Thanks @jbetech thats perfect.
You need to replace the ‘Log_to_feed’ Heat_kwh_3 with ‘Log_to_feed (join)’ and same for ‘Elec_kWh_pulsed_3’. This is a new input process specifically for this application, I’ve added a section to the guide here about it Calculating Daily kWh - Guide | OpenEnergyMonitor but likely still need to update the heatpump documentation
Sorry I realise you may be using emoncms.org? Im still working on updating emoncms.org with the new input processors
yes…
I can take a look at your account and see if I can fix it in the mean time if you are happy for me to do that?
You can use the wh_accumulator process rather than log_to_feed for ‘Heat_kwh_3’ and ‘Elec_kWh_pulsed_3’ to essentially remove the little gaps in those feeds that will cause a missing day if the missing datapoint happens to coincide with midnight.
The new process ‘Log to feed (join)’ is just meant to be a little more intuitive as using a process named: wh_accumulator on a cumulative kWh feed does not sound correct… and the limiter built into that process is also not applicable. But other than that they do a very similar function.
I can run a post processor on the feeds to fix the historic data if you like.
That would be great if you could take a look.
Thanks.
