Quite a few mains pressure cylinder manufacturers include statements like “Where the total hardness exceeds 125 ppm a high capacity water softener, or suitable water conditioner, should be installed in the incoming cold water supply to the cylinder”, with some explicitly disclaiming any warranty otherwise (but no statements on what type of conditioner are “suitable”).
Limescale on the heat exchange coil is of course not a good thing for long term efficiency, and we have hard water here (but not “very hard” - South Downs chalk aquifer 265 ppm CaCO3).
We have a (presumably) magnetic thingy on the water intake to the combi boiler, which was here when we bought the house. We do get a fair amount of limescale, but most water doesn’t pass through the magnetic conditioner.
There are products available which describe themselves as “template assisted crystallization” (TAC) water conditioners.
Their claim is that the incoming water passes through a fluidised bed of beads which have microscopic surface structure that encourage microscopic scale crystals to to form and then get released into the water. Further scale formation then preferentially takes place onto these crystals (including later on when the water is heated - so long as that occurs within “a few hours” - which is likely for a DHW cylinder).
Template Assisted Crystallisation is a real thing which is used in chemical processing, but I’ve only been able to find two studies on its use for water scale prevention in heat exchangers:
On TAC there is independent test data: a WateReuse Research Foundation study that compared alternatives to ion-exchange softeners found template-assisted crystallization reduced scale formation by more than 88 percent in their tests, while electromagnetic treatment managed roughly half. One thing to note: TAC does not soften the water, it only encourages scale to form as suspended crystals, so your water will still test hard. For the warranty question that distinction matters - ‘softener or suitable conditioner’ is the manufacturer’s wording, so I would ask the cylinder maker directly whether a TAC unit counts as suitable before relying on it. Hypothesis on my part: expect only ion exchange to be unambiguous.
Thanks - the “WateReuse Research Foundation” study is the one I linked above (the academics involved were from the University of Arizona). However the University of Waterloo found much lower efficiency (5% reduction).
Thanks Tim. No personal experience on my side, unfortunately - I do not have one installed (yet). I only came across TAC while researching options for our own limescale problem and collected the studies. The big spread between the reported field results and the Waterloo lab numbers is exactly what makes me hesitant too. Maybe someone here actually runs one and can share real-world numbers.
Not the same thing, but I use a BWT Combi Care it uses a Polyphosphate as a Scale Inhibitor. Been using for about 4 years and it has certainly reduced the scale issues around the house. We are on our own borehole and is a similar harness to yours but slightly higher at 305.
Thanks Johnmo - four years of good results on your own borehole water is a valuable data point. Polyphosphate takes a different route than TAC: it sequesters the hardness ions and keeps them in solution rather than crystallizing them (the Australian Drinking Water Guidelines describe this use). One caveat from my reading: polyphosphate slowly reverts to orthophosphate in water, and that happens faster at high temperature, so the protection is usually weaker on the hot side of a cylinder than on cold feeds. Good to hear it still cut the scale noticeably in your setup.
