# Hack my Heat Pump and publish data onto emoncms
**URL:** <https://community.openenergymonitor.org/t/hack-my-heat-pump-and-publish-data-onto-emoncms/2551>\
**Category:** emonPi\
**Created:** [20 December 2016 09:43 UTC](https://community.openenergymonitor.org/t/hack-my-heat-pump-and-publish-data-onto-emoncms/2551 "2016-12-20T09:43:02Z")\
**Showing post:** 45
**Author:** ![krakra](https://community.openenergymonitor.org/letter_avatar_proxy/v4/letter/k/a8b319/32.png) [@krakra](https://community.openenergymonitor.org/u/krakra)\
**Post date:** [17 January 2019 01:05 UTC](https://community.openenergymonitor.org/t/hack-my-heat-pump-and-publish-data-onto-emoncms/2551/45 "2019-01-17T01:05:25Z")
For those who want to play with BRP069A62 and websocket, I would recommed using Node Red.
It is fairly easy to read sensors and issue command to the unit, but as already mentioned, you only get the very basic data (the same data available through the Android Daikin Controler App).
Here is my flow (for Room Temperature mode). Do not forget to change the IP address in the websocket node. Sorry the flow is still a bit messy, but you will still get a basic idea how the websocket communication with LAN adapter works.:
[{"id":"7916defc.b11688","type":"tab","label":"Daikin 2","disabled":false,"info":""},{"id":"dbab4c0e.0d7f4","type":"debug","z":"7916defc.b11688","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":2450,"y":680,"wires":[]},{"id":"10f6ac81.c2c5e3","type":"change","z":"7916defc.b11688","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload[\"m2m:rsp\"].pc[\"m2m:cin\"].con","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1900,"y":180,"wires":[["dbab4c0e.0d7f4"]]},{"id":"40631846.3fe738","type":"json","z":"7916defc.b11688","name":"","property":"payload","action":"str","pretty":false,"x":1490,"y":300,"wires":[["6d502435.2c2174"]]},{"id":"6d502435.2c2174","type":"switch","z":"7916defc.b11688","name":"","property":"payload[\"m2m:rsp\"].fr","propertyType":"msg","rules":[{"t":"eq","v":"/[0]/MNAE/1/Sensor/IndoorTemperature/la","vt":"str"},{"t":"eq","v":"/[0]/MNAE/1/Sensor/OutdoorTemperature/la","vt":"str"},{"t":"eq","v":"/[0]/MNAE/2/Sensor/TankTemperature/la","vt":"str"},{"t":"eq","v":"/[0]/MNAE/1/Operation/TargetTemperature/la","vt":"str"},{"t":"eq","v":"/[0]/MNAE/2/Operation/TargetTemperature/la","vt":"str"},{"t":"eq","v":"/[0]/MNAE/2/UnitStatus/ReheatState/la","vt":"str"},{"t":"eq","v":"/[0]/MNAE/1/Operation/Power/la","vt":"str"},{"t":"eq","v":"/[0]/MNAE/2/Operation/Power/la","vt":"str"},{"t":"eq","v":"/[0]/MNAE/2/Operation/Powerful/la","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":10,"x":1650,"y":300,"wires":[["10f6ac81.c2c5e3"],["b4677899.c48018"],["b1d25218.05391"],["335c84f6.a0b244"],["747bf93f.042af8"],["9f5e02dd.1e6a"],["d906f42c.8661b"],["8d7b605c.5bfba"],["954c74a3.275e98"],["f7477e47.75c33"]],"outputLabels":["1 Indoor Temp","","","","","","","",null,""]},{"id":"4a281ecf.138be","type":"websocket in","z":"7916defc.b11688","name":"Daikin","server":"","client":"8ef83237.4e642","x":1330,"y":300,"wires":[["40631846.3fe738"]]},{"id":"55391ba3.bf7154","type":"status","z":"7916defc.b11688","name":"","scope":["4a281ecf.138be"],"x":160,"y":360,"wires":[["c895eac4.5e3e88"]]},{"id":"b4677899.c48018","type":"change","z":"7916defc.b11688","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload[\"m2m:rsp\"].pc[\"m2m:cin\"].con","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1900,"y":240,"wires":[["dbab4c0e.0d7f4"]]},{"id":"b1d25218.05391","type":"change","z":"7916defc.b11688","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload[\"m2m:rsp\"].pc[\"m2m:cin\"].con","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1900,"y":300,"wires":[["dbab4c0e.0d7f4"]]},{"id":"335c84f6.a0b244","type":"change","z":"7916defc.b11688","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload[\"m2m:rsp\"].pc[\"m2m:cin\"].con","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1900,"y":360,"wires":[["dbab4c0e.0d7f4"]]},{"id":"747bf93f.042af8","type":"change","z":"7916defc.b11688","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload[\"m2m:rsp\"].pc[\"m2m:cin\"].con","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1900,"y":420,"wires":[["dbab4c0e.0d7f4"]]},{"id":"9f5e02dd.1e6a","type":"change","z":"7916defc.b11688","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload[\"m2m:rsp\"].pc[\"m2m:cin\"].con","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1900,"y":480,"wires":[["dbab4c0e.0d7f4"]]},{"id":"25839005.de279","type":"trigger","z":"7916defc.b11688","op1":"{\"m2m:rqp\":{\"op\":2,\"to\":\"/[0]/MNAE/1/Sensor/IndoorTemperature/la\",\"fr\":\"/S\",\"rqi\":\"ynutj\"}}","op2":"","op1type":"json","op2type":"nul","duration":"250","extend":false,"units":"ms","reset":"","bytopic":"all","name":"1/Sensor/IndoorTemperature","x":1020,"y":180,"wires":[["e9238fd3.6c8288"]]},{"id":"e1cfb13a.c2eec","type":"trigger","z":"7916defc.b11688","op1":"{\"m2m:rqp\":{\"op\":2,\"to\":\"/[0]/MNAE/1/Sensor/OutdoorTemperature/la\",\"fr\":\"/S\",\"rqi\":\"jcmiz\"}}","op2":"","op1type":"json","op2type":"nul","duration":"250","extend":false,"units":"ms","reset":"","bytopic":"all","name":"1/Sensor/OutdoorTemperature","x":1030,"y":240,"wires":[["e9238fd3.6c8288"]]},{"id":"797d0e59.3910b8","type":"trigger","z":"7916defc.b11688","op1":"{\"m2m:rqp\":{\"op\":2,\"to\":\"/[0]/MNAE/2/Sensor/TankTemperature/la\",\"fr\":\"/S\",\"rqi\":\"awmvw\"}}","op2":"","op1type":"json","op2type":"nul","duration":"250","extend":false,"units":"ms","reset":"","bytopic":"all","name":"2/Sensor/TankTemperature","x":1020,"y":300,"wires":[["e9238fd3.6c8288"]]},{"id":"baa14c24.cc059","type":"trigger","z":"7916defc.b11688","op1":"{\"m2m:rqp\":{\"op\":2,\"to\":\"/[0]/MNAE/1/Operation/TargetTemperature/la\",\"fr\":\"/S\",\"rqi\":\"rcxag\"}}","op2":"","op1type":"json","op2type":"nul","duration":"250","extend":false,"units":"ms","reset":"","bytopic":"all","name":"1/Operation/TargetTemperature","x":1030,"y":360,"wires":[["e9238fd3.6c8288"]]},{"id":"63fbdae5.f21214","type":"trigger","z":"7916defc.b11688","op1":"{\"m2m:rqp\":{\"op\":2,\"to\":\"/[0]/MNAE/2/Operation/TargetTemperature/la\",\"fr\":\"/S\",\"rqi\":\"jhntt\"}}","op2":"","op1type":"json","op2type":"nul","duration":"250","extend":false,"units":"ms","reset":"","bytopic":"all","name":"2/Operation/TargetTemperature","x":1030,"y":420,"wires":[["e9238fd3.6c8288"]]},{"id":"5be1f665.6ea008","type":"trigger","z":"7916defc.b11688","op1":"{\"m2m:rqp\":{\"op\":2,\"to\":\"/[0]/MNAE/2/UnitStatus/ReheatState/la\",\"fr\":\"/S\",\"rqi\":\"vbmuy\"}}","op2":"","op1type":"json","op2type":"nul","duration":"250","extend":false,"units":"ms","reset":"","bytopic":"all","name":"2/UnitStatus/ReheatState","x":1010,"y":480,"wires":[["e9238fd3.6c8288"]]},{"id":"88277fd2.46de48","type":"trigger","z":"7916defc.b11688","op1":"{\"m2m:rqp\":{\"op\":2,\"to\":\"/[0]/MNAE/1/Operation/Power/la\",\"fr\":\"/S\",\"rqi\":\"qyfud\"}}","op2":"","op1type":"json","op2type":"nul","duration":"250","extend":false,"units":"ms","reset":"","bytopic":"all","name":"1/Operation/Power","x":990,"y":540,"wires":[["e9238fd3.6c8288"]]},{"id":"d906f42c.8661b","type":"change","z":"7916defc.b11688","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload[\"m2m:rsp\"].pc[\"m2m:cin\"].con","tot":"msg"},{"t":"change","p":"payload","pt":"msg","from":"on","fromt":"str","to":"on","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"standby","fromt":"str","to":"off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1900,"y":540,"wires":[["dbab4c0e.0d7f4"]]},{"id":"990e3305.f5c728","type":"inject","z":"7916defc.b11688","name":"1min","topic":"","payload":"true","payloadType":"bool","repeat":"60","crontab":"","once":false,"onceDelay":0.1,"x":310,"y":300,"wires":[["6e753022.1c65c"]]},{"id":"1d989609.73ab6a","type":"trigger","z":"7916defc.b11688","op1":"{\"m2m:rqp\":{\"op\":1,\"to\":\"/[0]/MNAE/1/Operation/Power\",\"fr\":\"/S\",\"rqi\":\"bhktc\",\"ty\":4,\"pc\":{\"m2m:cin\":{\"con\":\"on\",\"cnf\":\"text/plain:0\"}}}}","op2":"","op1type":"json","op2type":"nul","duration":"250","extend":false,"units":"ms","reset":"","bytopic":"all","name":"1/Operation /Power ON","x":770,"y":780,"wires":[["e9238fd3.6c8288"]]},{"id":"894bbdfe.41f6e","type":"trigger","z":"7916defc.b11688","op1":"{\"m2m:rqp\":{\"op\":1,\"to\":\"/[0]/MNAE/1/Operation/Power\",\"fr\":\"/S\",\"rqi\":\"bhktc\",\"ty\":4,\"pc\":{\"m2m:cin\":{\"con\":\"standby\",\"cnf\":\"text/plain:0\"}}}}","op2":"","op1type":"json","op2type":"nul","duration":"250","extend":false,"units":"ms","reset":"","bytopic":"all","name":"1/Operation /Power OFF","x":770,"y":720,"wires":[["e9238fd3.6c8288"]]},{"id":"6e753022.1c65c","type":"trigger","z":"7916defc.b11688","op1":"true","op2":"","op1type":"bool","op2type":"nul","duration":"250","extend":false,"units":"ms","reset":"","bytopic":"all","name":"trigger","x":590,"y":360,"wires":[["25839005.de279","e1cfb13a.c2eec","797d0e59.3910b8","baa14c24.cc059","63fbdae5.f21214","5be1f665.6ea008","88277fd2.46de48","7b70d1c9.6bcbe8","a635a681.30807"]]},{"id":"c895eac4.5e3e88","type":"switch","z":"7916defc.b11688","name":"","property":"status.text","propertyType":"msg","rules":[{"t":"eq","v":"connected","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":310,"y":360,"wires":[["6e753022.1c65c"]]},{"id":"6756f209.40f33c","type":"trigger","z":"7916defc.b11688","op1":"{\"m2m:rqp\":{\"op\":1,\"to\":\"/[0]/MNAE/2/Operation/Power\",\"fr\":\"/S\",\"rqi\":\"cgeci\",\"ty\":4,\"pc\":{\"m2m:cin\":{\"con\":\"standby\",\"cnf\":\"text/plain:0\"}}}}","op2":"","op1type":"json","op2type":"nul","duration":"250","extend":false,"units":"ms","reset":"","bytopic":"all","name":"2/Operation/Power OFF","x":770,"y":840,"wires":[["e9238fd3.6c8288"]]},{"id":"893e56a2.101e78","type":"trigger","z":"7916defc.b11688","op1":"{\"m2m:rqp\":{\"op\":1,\"to\":\"/[0]/MNAE/2/Operation/Power\",\"fr\":\"/S\",\"rqi\":\"cgeci\",\"ty\":4,\"pc\":{\"m2m:cin\":{\"con\":\"on\",\"cnf\":\"text/plain:0\"}}}}","op2":"","op1type":"json","op2type":"nul","duration":"250","extend":false,"units":"ms","reset":"","bytopic":"all","name":"2/Operation/Power ON","x":760,"y":900,"wires":[["e9238fd3.6c8288"]]},{"id":"7b70d1c9.6bcbe8","type":"trigger","z":"7916defc.b11688","op1":"{\"m2m:rqp\":{\"op\":2,\"to\":\"/[0]/MNAE/2/Operation/Power/la\",\"fr\":\"/S\",\"rqi\":\"tmroa\"}}","op2":"","op1type":"json","op2type":"nul","duration":"250","extend":false,"units":"ms","reset":"","bytopic":"all","name":"2/Operation/Power","x":990,"y":600,"wires":[["e9238fd3.6c8288"]]},{"id":"8d7b605c.5bfba","type":"change","z":"7916defc.b11688","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload[\"m2m:rsp\"].pc[\"m2m:cin\"].con","tot":"msg"},{"t":"change","p":"payload","pt":"msg","from":"on","fromt":"str","to":"on","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"standby","fromt":"str","to":"off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1900,"y":600,"wires":[["dbab4c0e.0d7f4"]]},{"id":"56268606.4b69d","type":"websocket out","z":"7916defc.b11688","name":"Daikin","server":"","client":"8ef83237.4e642","x":1470,"y":620,"wires":[]},{"id":"f7477e47.75c33","type":"debug","z":"7916defc.b11688","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1670,"y":620,"wires":[]},{"id":"a635a681.30807","type":"trigger","z":"7916defc.b11688","op1":"{\"m2m:rqp\":{\"op\":2,\"to\":\"/[0]/MNAE/2/Operation/Powerful/la\",\"fr\":\"/S\",\"rqi\":\"zlyhz\"}}","op2":"","op1type":"json","op2type":"nul","duration":"250","extend":false,"units":"ms","reset":"","bytopic":"all","name":"2/Operation/Powerful","x":1000,"y":660,"wires":[["e9238fd3.6c8288"]]},{"id":"d39f83b6.e60d9","type":"trigger","z":"7916defc.b11688","op1":"{\"m2m:rqp\":{\"op\":1,\"to\":\"/[0]/MNAE/2/Operation/Powerful\",\"fr\":\"/S\",\"rqi\":\"amwam\",\"ty\":4,\"pc\":{\"m2m:cin\":{\"con\":0,\"cnf\":\"text/plain:0\"}}}}","op2":"","op1type":"json","op2type":"nul","duration":"250","extend":false,"units":"ms","reset":"","bytopic":"all","name":"2/Operation/Powerful OFF","x":770,"y":960,"wires":[["e9238fd3.6c8288"]]},{"id":"70d2d8da.df4c9","type":"trigger","z":"7916defc.b11688","op1":"{\"m2m:rqp\":{\"op\":1,\"to\":\"/[0]/MNAE/2/Operation/Powerful\",\"fr\":\"/S\",\"rqi\":\"ibwib\",\"ty\":4,\"pc\":{\"m2m:cin\":{\"con\":1,\"cnf\":\"text/plain:0\"}}}}","op2":"","op1type":"json","op2type":"nul","duration":"250","extend":false,"units":"ms","reset":"","bytopic":"all","name":"2/Operation/Powerful ON","x":770,"y":1020,"wires":[["e9238fd3.6c8288"]]},{"id":"e9238fd3.6c8288","type":"delay","z":"7916defc.b11688","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1330,"y":620,"wires":[["56268606.4b69d"]]},{"id":"954c74a3.275e98","type":"change","z":"7916defc.b11688","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload[\"m2m:rsp\"].pc[\"m2m:cin\"].con","tot":"msg"},{"t":"change","p":"payload","pt":"msg","from":"1","fromt":"num","to":"on","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"0","fromt":"num","to":"off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1900,"y":660,"wires":[["dbab4c0e.0d7f4"]]},{"id":"99fcf1ed.0300b8","type":"inject","z":"7916defc.b11688","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":520,"y":720,"wires":[["894bbdfe.41f6e"]]},{"id":"cd028f03.9f113","type":"inject","z":"7916defc.b11688","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":520,"y":780,"wires":[["1d989609.73ab6a"]]},{"id":"844a112e.e980f8","type":"inject","z":"7916defc.b11688","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":520,"y":840,"wires":[["6756f209.40f33c"]]},{"id":"3825c7d3.1975e8","type":"inject","z":"7916defc.b11688","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":520,"y":900,"wires":[["893e56a2.101e78"]]},{"id":"c5f9b60.c1d2cc8","type":"inject","z":"7916defc.b11688","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":520,"y":960,"wires":[["d39f83b6.e60d9"]]},{"id":"bd568056.a9d358","type":"inject","z":"7916defc.b11688","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":520,"y":1020,"wires":[["70d2d8da.df4c9"]]},{"id":"8ef83237.4e642","type":"websocket-client","z":"","path":"ws://192.168.1.200/mca","wholemsg":"false"}]
_[View the full topic](https://community.openenergymonitor.org/t/hack-my-heat-pump-and-publish-data-onto-emoncms/2551)._
