Graphs
Hello,
which functions of these names are listed below?
Where do I find the algorithm that does the calculations?
thank you very much for your help.
Screenshot%20(42)
Is this not an EVSE question? If it is, then @glyn.hudson or @TrystanLea are possibly the best people to help you.
They should also be able to help you with this: Emoncms graph
These are the data Feeds you have available to graph. If you go onto the Feeds page you will see those same items listed.
If you select one of the check boxes the feed data will appear in the graph. there are 2 boxes, one for left scale and one for right.
