Hello Working on some of my data I notice that the one legend is missing in the Graph module. I created a new user and on that user both legends are available could there be a problem with my user account?
Regards
Paul
Regards
Paul
Hi Paul,
Could you select a feed on the LHS? Could you attach a larger screen shot? I’ve just tested on both emoncms.org and emonPi / emonBase and the graph looks fine to me. See attached.
Hi Glyn
I ended up clearing the SQL and the problem was back the moment I created new feeds. But it was only for User 1 any other user there was not a problem.
Short version is the problem was IO issues. I did re complete reinstall of emoncms into the SQL but never cleared the phpfiwa data folder. So when I created user one I imported the old user one data from the previous SQL (as the settings was already there) and there was where everything went pear shaped. After clearing the data folders al was running smoothly.
Regards
Paul
