Hi all,
I recently had a Grant Aerona 290 6.5kw installed only a week ago. The installer initially set it up to act similar to a traditional boiler system but after browsing online and coming across this forum and some Reddit posts, I learn’t that Pump Blockade off is a much more effective way to run the heat pump.
Anyway, I believe I’ve set everything appropriately to have the pump running ‘low and slow’ as recommended, what confuses me however is that I have the daytime temp set to 18c with a night setback of 17.5c, but as seen in the photos I’ve attached, the room temperature has reached 19c.
I understand that with pump blockade off, the compressor should turn off but the pump keeps circulating to maintain the air temperature by circulating the still warm water, but why is my compressor still running (albeit at low frequency).
I’ve attached photos below in the hope that someone can decipher what’s happening?
Heat Curve - 0.8 (0 shift)
Room temperature correction - 0c
Decrease fixed water temperature - 4c (no idea what this does?)
Daytime temp - 18c
Night temp - 17.5c
I had this idea in my head that once the room temperature reached 18c, the compressor would turn off, the pump would continue circulating warm water to maintain the temperature until the water cooled enough not to maintain the air temperature, the temperature would gradually drop and then the compressor would kick back in to top up the water temperature?
Will any damage be done by the compressor and fan running constantly at the moment as presumably it won’t turn off now? Unless I turned pump blockade back on.
