Good news for a change
I thought it would be good to share the solution I adopted for calibrating my recently purchased EmpnPi. After a fair bit of faffing about I managed to get the system working but the live power figures were reading about 10% high. I looked at the AC mains figure and that was also 10% high compared to my fluke DMM so I inserted a resistive divider to allow the measured AC to be adjusted to equal the DMM and now everything is spot on.
Happy bunny now.
You could have altered the “scales = …” values in emonhub.conf to achieve the same result.
Excellent! thank you Robert, I shall give that a go.
Changed from 0.01 to 0.0095. Now much more accurate, thank you.
Bear in mind that the maths to calculate power is done a long time before the data reaches emonHub, so you must apply the same scaling to the powers as well as the voltage.
