I’ve been lurking on the heat-loss / emitter threads and built a small visual tool for the bits I kept getting stuck on: draw the floor plan, set wall/window types, get per-room heat loss, then check emitters and pipe runs. All in a way that is super super easy, no need to be a physics major, it’s all visual. You can save different projects and subprojects, including read-only sharing, all free.
The current tools out there are either ridiculously expensive and/or complicated while, in first principles thinking, those few Watt’s precision don’t matter if the heatsource choice jumps in 1000’s of Watts and a good estimate could be achieved in less than 10min.
Take a look at heatlosspro.cloud (NL/FR/DE too), i’d love feedback to make it as good as possible. Tablet/phone friendly too.
Disclosure: I’m the maker. Code OEM1 to make one-off calculations free, giving away 100, no limit per user.
Would love a sanity check from people here who already meter their systems: does the per-room + emitter view match how you actually decide flow temp and radiator upgrades, or am I missing something obvious?
Thanks for sharing @gac123. Have you considered making this open source? I’d be interested in collaborating on an open source tool, building on the work I did years ago, on a not so user friendly tool here GitHub - TrystanLea/heatlossjs: Simple room by room heat loss calculator · GitHub I got claude to build a 2d floor planner for it the other day which I mentioned briefly here: Heatlossjs app has disappeared - #3 by TrystanLea but it needs a bit more time spent to make it nice. Still I think there’s a real opportunity for a nice open source tool for this..
Thanks Trystan, and congrats on heatlossjs and the work you’ve put into making heat loss approachable over the years! I wish I knew about it years ago
Open source is where a lot of this should and will end up, and I’d love a healthy OSS option for people who want to dig into the code. For HeatLoss Pro I’m still in a different place: I built it for the me from three years ago. I installed myself a heat pump and ended up with an undersized unit. The tool now confirms what I felt at the time and graphs almost exactly what the expected temperatures will be, which is quite an innovative feature, to my knowledge. Since then I’ve been extending it for the after-the-fact stuff too that I actually need today: adding insulation on existing surfaces, and a visual custom insulation / wall builder so you can try options on the real fabric instead of only on a spreadsheet.
Fun thing I’ve learned, is that insulation thickness is similar to a reverse exponential function, you save the most loss with the first mm’s, at about 12mm it’s really a point of diminishing returns, every extra millimetre buys you less and less loss. But if you have a lot of wall to cover, those extra savings do add up, but at an exponential higher cost. So it depends heavily on your time horizon for your living situation.
Happy to compare notes on the floor-plan / room-by-room side if useful. Your heatlossjs + planner idea is exactly the kind of foundation an open tool needs. I understand OSS doesn’t have to mean free but with AI these days anything could be copied in a matter of minutes and until Github works on these safeguards I’d prefer not spoonfeeding them.
