Hello
Follow some URL to get all ID’s of Feeds in JSON Format
https://iks.koisupport.ch/feed/list.json
Is there also possible to get the ID’s of all created Multigraphs?
Thanks for any hints.
Best Regards
Gregor
Hello
Best Regards
Gregor
You can get a full and detailed list of multigraphs with all the configuration but not just a list as far as I know.
http://emoncms.org/vis/multigraph/getlist.json&apikey=abc123
You can also delete, create new and edit multigraphs via the api although I don’t recall seeing this documented anywhere
I have opened an issue on the emoncms repo as the response to the getlist
api is not right, every quotemark in the feedlist is escaped by a backslash which shouldn’t be the case,
Hello Paul
Thanks for your solution, it is exactly what i need.
Best Regards
Gregor
