This morning I am getting a similar error message - when looking at the new MySolarBattery app view. It seems to pop up only after the view has been displayed for a few minutes.
EmonCMS Error
Message: TypeError: undefined is not an object (evaluating ‘series.data[item.dataIndex][1]’)
Route: app/view?name=2020-05-18+My+Solar+Battery
Line: 1043
Column: 53
Looking within (local) emonCMS / Admin, I am running 10.2.3, all services are Active/Running. At the risk of incurring @borpin 's ire , where should I look for Line 1043, Column 53?
LAST ENTRIES ON THE LOG FILE
2020-05-22 04:01:33.964|WARN|index.php|Time string not valid 2020-05-12T22:30:00 01:00
2020-05-22 04:01:37.145|WARN|index.php|Time string not valid 2020-05-12T23:00:00 01:00
2020-05-22 04:01:37.948|WARN|index.php|Time string not valid 2020-05-12T23:30:00 01:00
2020-05-22 04:01:39.913|WARN|index.php|Time string not valid 2020-05-13T00:00:00 01:00
2020-05-22 04:01:42.269|WARN|index.php|Time string not valid 2020-05-13T00:30:00 01:00
2020-05-22 04:17:51.893|ERROR|index.php|Invalid JSON: "Error: connect ETIMEDOUT 192.168.2.74:443 : https://192.168.2.74/api/meters/aggregates"
2020-05-22 04:17:51.894|ERROR|input_controller.php|{"success": false, "message": "Input in not a valid JSON object"} for User: 1
2020-05-22 04:25:30.993|ERROR|input_controller.php|{"success": false, "message": "Format error, json value is not numeric"} for User: 1
2020-05-22 04:41:11.198|ERROR|input_controller.php|{"success": false, "message": "Format error, json value is not numeric"} for User: 1
2020-05-22 04:53:32.590|ERROR|index.php|Invalid JSON: "Error: connect ETIMEDOUT 192.168.2.74:443 : https://192.168.2.74/api/meters/aggregates"
2020-05-22 04:53:32.591|ERROR|input_controller.php|{"success": false, "message": "Input in not a valid JSON object"} for User: 1
2020-05-22 05:45:13.459|ERROR|index.php|Invalid JSON: "Error: connect ETIMEDOUT 192.168.2.74:443 : https://192.168.2.74/api/meters/aggregates"
2020-05-22 05:45:13.460|ERROR|input_controller.php|{"success": false, "message": "Input in not a valid JSON object"} for User: 1
2020-05-22 06:06:42.744|ERROR|index.php|Invalid JSON: "Error: connect ETIMEDOUT 192.168.2.74:443 : https://192.168.2.74/api/meters/aggregates"
2020-05-22 06:06:42.745|ERROR|input_controller.php|{"success": false, "message": "Input in not a valid JSON object"} for User: 1
2020-05-22 06:21:03.519|ERROR|index.php|Invalid JSON: "Error: connect ETIMEDOUT 192.168.2.74:443 : https://192.168.2.74/api/meters/aggregates"
2020-05-22 06:21:03.520|ERROR|input_controller.php|{"success": false, "message": "Input in not a valid JSON object"} for User: 1
2020-05-22 06:28:33.190|ERROR|index.php|Invalid JSON: "Error: connect ETIMEDOUT 192.168.2.74:443 : https://192.168.2.74/api/meters/aggregates"
2020-05-22 06:28:33.191|ERROR|input_controller.php|{"success": false, "message": "Input in not a valid JSON object"} for User: 1
2020-05-22 06:30:33.613|ERROR|input_controller.php|{"success": false, "message": "Format error, json value is not numeric"} for User: 1
2020-05-22 06:57:13.120|ERROR|input_controller.php|{"success": false, "message": "Format error, json value is not numeric"} for User: 1
2020-05-22 07:01:43.289|ERROR|input_controller.php|{"success": false, "message": "Format error, json value is not numeric"} for User: 1
2020-05-22 07:50:59.261|ERROR|index.php|Not Authenticated|app/setconfig
2020-05-22 07:51:12.272|ERROR|index.php|Not Authenticated|app/setconfig
2020-05-22 08:03:18.804|ERROR|index.php|Not Admin|admin/view
Just to resurrect this thread - getting a similar error when I tried to add the My Solar Battery app, and now I can’t remove the app either from the list (as it errors before loading any screen).
This appears to still be an issue. I get the same error. I am running a display with the app in a browser and sometimes I get this error displayed. The only way to clear it is to reload the page.
It’s not a massive problem but it is inconvenient.
Maybe it has something to do with wifi network dropping out overnight?
I think I can replicate something similar with the code from the trim_start function in timeseries.js. If the tmpdata array in trim_start does not get populated with at least two array entries we get an error.
