Hi all, I’ve been trying to get a fresh clean install of Ubuntu server with emoncms 9.6, now 9.7 working but I’m not having any luck.
I’ve tried with Ubuntu 14.04 and 16.04. Followed the installation instructions verbatim and cannot get emoncms to work.
I only get the login page displayed. If I try to create a new user all I get is “undefined”.
sound again the apache redirect option is missing : mod_rewrite option active ?
the create button sends to a particular script that is not really called statically but via an url_rewrite
not 100% sure it is this but in my case it was the problem (though not on Ubuntu)
Hi, I had the same problem a few hour ago.
I just solved installing phpmyadmin on my Ubuntu and granting permissions to the emoncms db user.
Hope this helps.
Yup, hosting from /var/www/html/emoncms.
Interestingly, the timestamp on the apache2.conf file dates back to 2014
contents of /etc/apache2/sites-enabled/emoncms
<Directory /var/www/html/emoncms>
Options FollowSymLinks
AllowOverride All
DirectoryIndex index.php
Order allow,deny
Allow from all
</Directory>
AllowOverride All
Order allow,deny
Allow from all
</Directory>
Hi again Glyn, yup.
I certainly did follow those steps.
I’ll run another fresh install tonight and double check that the “AllowOverride All” directive actually gets added.
If it helps, I have emoncms 9.7.8 | 2016.11.10 at latest revision as of yesterday running on an Ubunti 16.04 server with no problems. Here is the public demo dashboard:
