A phpfina feed with a fixed interval of 10s will occupy around 12Mb per year (4b per datapoint x 8640 points per day x 365 days) so it’s not as crucial as you might think to conserve space unless you have many hundreds of feeds or a very small SDcard. As for the write frequency, all feed data is buffered and written to disk periodically (each 60s by default) so disc wear is also not so much of factor when choosing a feed’s fixed interval.
But, if you do wish to minimize disc writes and space used regardless then the raw power data is the most valuable source data and that cannot easily be reconstructed once lost, so (for example) you could save just your power data as 10s to retain granularity in case of a future change in plan etc and then review your other feeds eg the power to kWh feeds can be reconstructed at any time from the power data using the post-process module. Plus the calculations performed by the power to kWh process are held in memory by Redis and continue to get updated on each input update even if the fixed feed interval is greater than the source updates.
eg a processlist like so
Log to feed “power1” phpfina 10s
Power to kWh “power1_kWh” phpfina 60s
being updated every 10s by your emonTx would record the raw source power data close to original as that feed would get updated every 10s whilst the power to kWh value would get calculated and updated in RAM only and then on every 6th input update that current calculated value would get written to the feed once every min. The same would apply to a fixed interval of an hour or a day etc.
There is an accuracy vulnerability though because if the Pi is rebooted or Redis flushed inbetween the min/hour/daily fixed intervals the change since the last min/hour/daily fixed interval is lost.
IMO you are better to just log at a higher resolution than you need unless space is really tight as the above example (using a 60s interval over a 10s interval) will only save you 10Mb per annum (that may be significant if you have hundreds of feeds).
The raw power data “log to feed” process doesn’t do any averaging etc so if you were to save your 10s incoming data every 60s you will just have a 10s snapshot each minute that may not reflect the true picture, the unused values that are not saved to disc would be lost forever, you cannot regain that resolution in the future.
You may be surprised how revealing that extra granularity is, it will help recognize loads and possibly even reveal issues otherwise hidden from view, this greater resolution is the reason using CT’s is so much more useful than pulsecounting alone. Low res data is only good for recording consumption/generation etc whilst high res power data is better suited for debugging, control and management of consumption/generation. It basically boils down to whether you are just keeping records or actively managing consumption/generation.
Of course it’s for you to decide what fits your needs best, but disposing of such detail might not have a huge benefit (space and resources wise) but at some point some detailed historical data might prove useful.
The emonTH and temperture data in general is usually at lower resolution because a) temperature change is generally slower than changes in energy consumption, and b) the emonTH’s are battery powered so getting batteries to last 6x longer is more significantly more useful than reducing the data’s size on disc.
[edit - just for clarity, the suggestion of saving the power to kWh data to a feed of a lower interval is theoretical
(ie untested by me) and with the emonPi/SD in mind, it is totally dependent on Redis being used so the “last update” is NOT retrieved from the feed directly].
