Good People,
Paul very kindly helped me with setting up my weatherstation data inputs into my emonpi emoncms. I have been hunting around and am only guessing but to feed this same data into emoncms.org I would have to edit the EMONHUB configuration to add a new node. I’ve created a draft and would confirmation that this looks okay and is the way to proceed. I’ve not included the “datacodes” and in the “units” I’ve used the character “n” when I didn’t know the correct code.
[[27]]
nodename = weatherstation
[[[rx]]]
names = temp_outside_back,humidity_back,dewpoint,windspeed_10min_avg,windspeed_curr,wind_bearing,curr_rain_rate,rain_today,pressure,wind_speed_beaufort,wind_run_today,pressure_trend,temp_dining_room,humidity_dining_room,wind_chill,temp_trend_back,heat_index,solar_radiation,wind_bearing_10min_avg,rain_last_hour,curr_forecast,is_it_daylight,cloudbase,temp_apparent_back,sunshine_hours_today,curr_theoretical_max_solar_rad
scales = 0.1,1,0.1,0.1,0.1,1,0.1,0.1,0.1,1,0.1,0.1,0.1,1,0.1,0.1,0.1,1,1,0.1,1,1,1,0.1,0.1,0.1
units = C,%,C,n,n,n,n,n,n,n,n,n,C,%,n,n,n,n,n,n,n,n,n,C,n,n
Appreciate any help.
John
