feedwriter.php did hang tonight and after some debugging i found the following:
Processing feed=183 len=3 :
Reading block 50000
Invoking post_bulk_save engine=2
Processing feed=184 len=3 :
Reading block 50000
Processing feed=185 len=3 :
Reading block 50000
Processing feed=214 len=54 :
Reading block 50000
Processing feed=216 len=682 :
Reading block 50000
mmap() failed: [12] Cannot allocate memory
PHP Fatal error: Out of memory (allocated 538968064) (tried to allocate 534773768 bytes) in /var/www/emoncms/Modules/feed/engine/PHPFina.php on line 711
If i restart the whole system or only the service it will break again.
Any idea? Should i open a GitHub Issue?
