Hi All,
I used EmonCMS without problems for some years.
My old Synology died for a few days
So I bought a QNAP (TS251+), I installed Debian 10 in a container using docker.
Also installed using the script, EmonCMS Version 10.2.2 (low write).
All fine, except two thing.
feedwriter: Activating Auto-restartService is not running10 feed points pending write (after a restart, all data are lost on Emoncms)
I searched over the internet for the right user/password to log me in in the console, no chance to find the right combination of the words, emoncms/emonpi? emonpi/emonpi2016 ?
Any help is appreciated and finally, sorry for my English
Im using a docker Debian LXC version, after reboot it ask me for a password that I not have, I try again with another Debian docker version and let you know, finally I think I have to switch to an real raspberry.
I run emoncms for the last 4 years on my sinology, without problems, as my sinology died, I bought a Qnap251+ , and now all these problems happens I let you know…many thanks for your help
Hi again Brian,
I installed it freshly (Debian 10 LXC on a container), because these LXC package generate a random password, is for me not possible to enter on the system, so I put your command just after the emoncms installation, the result are the same as in this topic, here below the result.
I expect you can change the password immediately after install? The random password will be so there is not a universal password out in the wild.
So the attempt to change the ownership of the folder is failing on starting the service.
You need to investigate from the command line why this is. The line before seems to say the creating of the folder was a success.
If you cat /var/www/emoncms/scripts/services/feedwriter/feedwriter.service you will see the value of $USER. It could be that, as you did not change the user in the configuration file, this is the issue. The user should be the same as the logged in user when running the install script.
If you install the container as the user pi things will work better. Eles change the configuration for the emoncms install to match the logged in user.
