Happy New Year.
At the beginning of last year I attempted to fill some gaps in a feed and accidentally generated timestamps that were for December 2024, rather than 2023. Since then I have been manually copying the feed data each day from my local emoncms to the hosted instance. I was hoping that once the date had passed that erroneous data the sync would start working again but sadly it is still not syncing that feed. The other three are working fine.
Hello @LeiChat if you delete the feed on emoncms.org and re-upload that should hopefully fix it. Alternatively if you want to preserve the version on emoncms.org you can delete the local, download it and then reconfigure the input processing before syncing it up again…
If the remote feed has a different start time or more data points in it than the local feed it will not upload new data. It sounds like there’s an inconsistency somewhere…
If I downloaded both and merged them, could I delete the feed from both instances and start again by uploading the merged data? The thing I really want to avoid is starting from fresh with either feed.
