Had a stange thing happen - yesterday I changed some feeds from private to public. I did this by multi-selecting tick boxes accross several nodes (this is an exampe, not the actual feeds I edited):
‘power2’ was in node emontx1, ‘battery’ and ‘Outside temp2’ were in node emonth6
All the other feeds which are now not updating are the ones that are supposed to be there (node Heatpump).
When I look at the inputs page, the Heatpump inputs that I was using (4 x temp inputs) have all been duplicated and the originals are now not sending data:
Yes sadly this does happen because you renamed all of the Nodes at the same time When you selected the Public checkbox).
It does say it cannot rename multiple feeds, but there should be something to prevent this happening. @TrystanLea@emrys. You are not the first.
If the feed is still there, you can just select it and rename the node name. If the duplicate feed names mean one is gone, there may be nothing you can do.
On the inputs page, delete the new inputs and it may simply correct itself.
