HI all,
I’m trying to get a better sense of the archtecture of the code on the EmonPI - who talks to who?
I have the commercial EmonPI, with a EmonTX and a couple of EmonTH. I also have a HomeAssistant system and programming skills.
I’m trying to understand how EmonHUB, the MQTT layer and EMONCMS go together.
When I watch the MQTT events I see events from the various sensors. My understanding is that EmonHub makes those events as it reads data from the sensors. Is that right?
Now how does this stuff get into EmonCMS? Does EmonCMS read those events from MQTT, or is EmonHUB pushing them directly to EmonCMS in parallel?
I made a little temperature/humidity probe out of an ESP8266 and DHT22. I published the values from that into MQTT in the same style that I saw coming from EmonHUB and EmonCMS is happy to treat them as an input. So I guess EmonCMS must read from MQTT, right?
Now I’ve got some code that can read stuff off my inverter and my Lithium batteries.
At the moment the monitor on my inverter is making a JSON payload and publishing to MQTT like so:
"InverterTime":"20181224102320",
"TotalProduction":0,
"GridVolts":213.4,
"GridWatts":-67,
"GridHz":50.0,
"LoadAmpsMaybe":0.3,
"LoadVolts":212.9,
"LoadWatts":0,
"LoadHz":50.0,
"LoadAmps":0.0,
"LoadPercent":2,
"DCBusVolts1":440.7,
"DCBusVolts2":440.7,
"BatteryVolts":53.2,
"BatteryPercent":100,
"PVWatts":0.0,
"PVVolts":49.7,
"InverterWatts":0,
"Temp":42.0,
"BatteryChargeMode":"F",
"BatteryChargeAmps":0.5,
"BatteryFloatVolts":53.2,
"BatteryMaxChargeAmps":25.0,
"BatteryBulkChargeVolts":53.2
For my batteries I’m reading:
> VoltageUpLimit: 53.25, VoltageDownLimit: 47.0, MaxChargeCurrent: 25.0, MaxDischargeCurrent: -250.0, Status: 0xc0
> CellsCount: 15, TemperaturesCount: 5
> TotalCurrent: 0.000A, TotalVoltage: 53.185V, RemainingCapacity: 50.000Ah, P: 0.00
> Quantity: 2, TotalCapacity: 50.0Ah, Cycles: 0
> CellVoltages: [3.547, 3.546, 3.538, 3.542, 3.547, 3.525, 3.546, 3.548, 3.549, 3.549, 3.55, 3.549, 3.549, 3.55, 3.55]
> Temperatures: [28.0, 25.0, 25.0, 25.0, 25.0]
I’ve got this info for each of 2 packs
I’d like to get all this stuff into EmonCMS, and also be able to see it via MQTT in HomeAssistant and manipulate with NodeRED.
But to publish each item on a separate topic is a lot of messages.
But EmonCMS can’t read JSON I don’t think.
I see that the EmonTX publishes all the values in one string, but I’m not sure how the EmonPI knows what they all represent?
What’s the best practice - to have my probes publish into MQTT - then I can see the raw event in HomeAssistant and EmonCMS - but I can’t use the structured JSON format.
Or to use the EMONCMS API?
Or to publish and have NodeRED republish to MQTT and back into EmonCMS.
I’d appreciate any pointers and hints,
Steve
