after setting up an account on emoncms everything works fine.
Now i want to sync all data to my local emoncms on raspberry.
Setting up the raspberry with the sd card image worked well, updating also.
After syncing with the remote emoncms.org i get this failure when i’m lloking at the inputs.
Thank you Bill
Once more i’ve done the setup again.
Changed the wrong file link in settings.php to
/var/opt/emoncms/phpfina … fiwa …
So no failures in the log file, but when refreshing size there are no data. The size should be around 21MB.
