hi
on http://appenzeller-energie.ch/furth.php#monatsproduktion we visualize our energy work (kWh) with d3js d3js.org/
for a while we use now a emonpi which stores the data in a selfhosted emoncms (v9.7). the visualisations can be seen on http://appenzeller-energie.ch/furth_pilot.php.
it works very well (thanks!) but there are some open questions.
- did already someone using d3js with emoncms data?
the question might be WHY using d3js?
because:
i failed to add a work (kWh) feed from a power (kW) input.
according to guide.openenergymonitor.org/setup/daily-kwh/ going to input and adding a power to kWh process changes this node. there should be a new feed with kWh beside the existing kW feed? -
there are 2 alarm nodes which sends bit data, which needs to be "boned“ for getting usable information. can this be done in emoncms somehow? e.g. create for each bit a new virtual feed which shows then 0 or 1 in "green“ or "red“?
thanks a lot
stof
(sorry, new users only can add 2 links in a post )
