borpin
(Brian Orpin)
16 March 2022 10:39
#1
When you ‘mouse over’ a feed, it gives a small popup with a load of data about that feed.
@TrystanLea , could there be some way to view that data in a way that can be shared? The API only gives an abbreviated list of info.
Basically an option at the top that combines all the different info such as
The info in the Pop-up
The info in the Feed edit box (public, units etc)
Feed size
I’d suggest the same for the Input Processes against an Input.
Hello @borpin what do you mean by ‘in a way that can be shared?’
I can relatively easily extend the feed/getmeta api but extending the feed list view itself to provide this in a copy and paste kind of way is a bit more difficult.
borpin
(Brian Orpin)
16 March 2022 12:36
#3
Just that - so if there is an issue for instance, the user can share the info.
API is all and well, but for instance, the time stamp is not a string.
If the API is extended, could there be a button at the top to call it and format the result in a popup?
It would be good to have all that information in one place as well
