What is the best way to extract the data from an old EMONCMS vlow-write-v8.5 system running locally on a RPi B?
I tried to sync, but it keeps rejecting with “Authentication failure, username or password incorrect”. I assume there is not the required code on such an old system to support it.
I tried exporting just six weeks of data to and it rejected it saying it is too large. I have years of data, some of which is on emoncms.org, but there is some missing which is only on this old system. Is there a way to allow a larger downloads?
Alternatively transferring the data files to a system running current version. I assume the file format has changed.
UPDATE:
I will try using one of the scripts in this thread: Request datapoint limit until 8928 points
UPDATE 2:
This script has worked for the current local version of Emoncms (9.8.31 | 2018.06.21) and is quite fast.
A little more information to make the script easier to use:
Make a directory called MyApps in your home directory (typically this would be /home/pi/MyApps).
Make a text file called phpfina-csv-export.php.
Copy the code in the link to the file above.
Make the changes to the file as suggested in the post.
Copy phpfina-csv-export.php to /home/pi/MyApp
From that directory run the script by typing sudo php phpfina-csv-export.php
