Hello,
Is there a way to configure or otherwise give access to someone to export csv data but not to enable them to have access to the setting and configuration options of the feeds? Something similar to using the read-only api key to viewing dashboards?
Hello @fmqs it is possible to make a feed public and then share the link to the graph page. Here’s a domestic solar PV feed on emoncms.org as an example: Emoncms - graph 125788
You can then export the data in the view as CSV at the bottom.
It doesn’t give full CSV export of the entire feed but might be useful you just want to export more manageable amounts for further analysis in a spreadsheet.
